Find ZB family
10-21-2016, 08:37 AM | #1 |
36
Rep 398
Find ZB family
I.
Need to update with winkpf a dde 5. From Zb number I can't find correct family. How can i chose correct family in confort mode in winkpf? Thanks |
10-21-2016, 09:23 AM | #2 |
529
Rep 2,503
You need the SGBD:
1. Start INPA by right-clicking INPALOAD.exe file and selecting 'Run as administrator'. INPA should load 2. Select your relevant car. press F3. 3. The Script selection window will appear. Select the 1st option on the right - FUNCTIONAL JOBS 4. The Select series (Baureihenauswahl) window will appear. Select F1 5. The Job main menu will appear. Select F2 - Identifikation ***Ignore the red square but look in the SGBD column. There's your ecu family*** |
10-21-2016, 09:59 AM | #4 | |
529
Rep 2,503
Window will appear with current zusb and proposed update. |
10-21-2016, 03:46 PM | #5 |
36
Rep 398
Problem is that I dont know what family to chose, because when I input ZB number, it's not found on assembly.
10-21-2016, 05:57 PM | #6 | |
Ballin' out of control.
520
Rep 1,289
http://www.e90post.com/forums/showpo...48&postcount=2 If you found this information useful, please click on the Appreciate button at the bottom of this post.
Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms
10-21-2016, 09:20 PM | #7 | |
263
Rep 1,173
So, take the number that shows up in INPA and go to the DDE* folders in C:\EC-APPS\NFS\data and open each of the .his files and do a search for that number. If it finds it, then you know which family to select in WinKFP. If none of the .his files have that number, then google "BMW #######" (using the number from INPA) and see what you find. If you need the specific DATEN set your current version is a part of, you may have to search all the way back to around v49. Just depends on when the last time your car was updated. |
10-21-2016, 11:23 PM | #8 | |
529
Rep 2,503
If you want to just update a module why are you entering any zusb? Winkfp will choose the correct zusb automatically... |
10-22-2016, 06:30 AM | #9 | ||
36
Rep 398
10-22-2016, 06:32 AM | #10 | ||
36
Rep 398
