BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > air scoops
      10-21-2016, 06:43 AM   #1
32valves
32valves's Avatar
109
Drives: 2011 335d sport
air scoops
has anyone put air scoops on there car, and have you seen any benefits for air getting rammed to the turbos?
      10-21-2016, 07:05 AM   #2
chau
chau's Avatar
28
Drives: 335d
lol here we go...
      10-21-2016, 07:12 AM   #3
32valves
32valves's Avatar
109
nevermind I did a search on this forum...
      10-21-2016, 08:00 AM   #4
BB_cuda
BB_cuda's Avatar
765
Drives: 2011 335D Msport, 2013 X5D
32, it's too late. You're in for it now 😎
      10-21-2016, 08:17 AM   #5
32valves
32valves's Avatar
109
I tried to delete it but no happs.
Anyways I ordered some Macht Schnell scoops yedterday, and didn't think to research it but I probably should have ordered a water/meth controller instead.
I'm still running a Hobbs switch, oh well...
      10-21-2016, 08:19 AM   #6
32valves
32valves's Avatar
109
scoops
at least they look better than the other brands...
      10-21-2016, 08:19 AM   #7
TorqueAddict
TorqueAddict's Avatar
171
Drives: 340i - 335D
I dont know whay there is such a hate for scoops. They add HP and Puerto Rican 335d has proved it. Plus they get you laid.
JR Auto tune and Bohl Diesel Downpipe - KWv2 coils - Apex Racing 18" EC7 wheels wrapped in Michelin PSS 245/275 F/R - Zimmerman cross drilled rotors F/R with Hawk HPS pads - SS brake lines - Motul RBF 600 - ADD W1 oil catch can - BMW performance CF spoiler
Appreciate 3
      10-21-2016, 08:21 AM   #8
32valves
32valves's Avatar
109
when I did my search, there were more negative comments than positive. lol
      10-21-2016, 08:44 AM   #9
GottaBeKD
GottaBeKD's Avatar
136
Drives: 335d
Don't listen to those non believers... Get the red ones... I think its been scientifically proven that the red paint used has similar properties to the lubricant used by Clark Griswold on the sled disc allowing for reduced friction and increased ram effect. Just ask PR about it.
      10-21-2016, 08:52 AM   #10
larrysing
larrysing's Avatar
95
Drives: 2011 335d M-Sport, Nav/Blinds
2011 BMW 335d  [0.00]
HAHA Red scoops cost me a hole in my condenser and a $925 repair bill !!
Although on my daughter's car we have some ECS ones that DON'T rub in the back and do look BITCHIN !!
      10-21-2016, 11:49 AM   #11
Puerto Rican 335d
Puerto Rican 335d's Avatar
Puerto Rico
229
Drives: Montego Blue 335d
jajaja you guys aint shit. ,mines are still on and they do work properly jajajajaja
RENNtech Flash(Lenny Wu)/WAGNER IC
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD
Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now)
      10-21-2016, 12:52 PM   #12
lnxguy
357
Drives: 2009 335D
Lol ram air turbos
      10-21-2016, 01:13 PM   #13
135i_vs_
135i_vs_'s Avatar
72
Drives: M5, 135i, 335d, F10 550xi
Do they work?
Lol, must say, I had them on my 135i mainly for aesthetic purposes since I had a red interior. Of course I was curious if they would provide any benefit or not.
On the 135i, I felt it was pointless, as the air was already channeled nicely into the intake, forced by the twin turbos. I really don't think I felt a noticeable difference.
There are a few independent dyno graphs from the skeptics of these products, however, it is on an N/A V10 M5 and V8 M3, claims ranging from 4-14hp.
Seems they are effective at higher speeds to channel air for N/A engines.
Yet to see any hp+ claims with dyno for turbo charged cars.
      10-21-2016, 01:41 PM   #14
Puerto Rican 335d
Puerto Rico
229
135i_vs_ I concur w you its noticeable at higher speeds as far as dyno I never did do it.
      10-21-2016, 02:52 PM   #15
Nadir Point
Nadir Point's Avatar
103
Drives: Diesel
I was thinking about something like a combo cowl-induction/pro-stock setup like this:
      10-21-2016, 04:00 PM   #16
Hoooper
213
Drives: 335D
OP your mistake was not getting the RED SCOOPS those are the most effective, plus they will leave you with NO CODES!!
      10-22-2016, 07:15 AM   #17
Puerto Rican 335d
Puerto Rico
229
Yep red ones and no codes haters jajaja
      10-23-2016, 12:32 PM   #18
nicklockard
43
Drives: 2009 w/Nav; paddleshifters
The limitation is the TINY holes which are in the horizontal plane. Their surface area (or port size) to pass air is significantly smaller than the 3" diameter intake tubing.
Also the air has to take a two 90 degree bends in rapid succession. One is un-radiused or virtually instantaneous--the transition from outside, horizontally oriented, laminar-flow air to quickly vertical, then a radiused transition to horizontal again into the airbox. This is to keep bugs, large debris, and heavier objects out of the airbox. I believe it was also designed this way to take outside, pressurized, laminar flow air and transition it to turbulent flow (increased massflow rate) and for sound abatement.
If you can open up these holes to exceed the port flow area of the tubing behind it, then perhaps your scoops could begin to make a difference.
Last edited by nicklockard; 10-24-2016 at 10:53 AM.. Reason: edited 'faster moving' to increased massflow rate.
      10-24-2016, 09:47 AM   #19
Frediesel
Drives: 318is
Rapid succession, horizontal and red lipstick on DSLs- got it.
      10-24-2016, 10:19 AM   #20
dzlmoose
dzlmoose's Avatar
Egypt
122
Drives: Trek 7.2, 2001 M5
Chicks dig guys with Red Scoops and no codes.
      10-24-2016, 10:52 AM   #21
nicklockard
43
Yeah, whatever gains *could* theoretically be there are buried behind doing other mods first. I will not be the first to hog out those holes. Please, someone else do the testing
      10-24-2016, 11:51 AM   #22
TDIwyse
614
Drives: 2011 335d
Your comments about the OEM setup were right on the money. But, it is pretty easy to improve things a lot and keep the stock filter.
Lots of testing and data in this thread:
http://www.e90post.com/forums/showthread.php?t=1179619
2011 335d 11.68 @ 125.71 mph 1/4 mile NHRA certified track
Ram Cummins with lots-o-mods
