Will this Work?
10-21-2016, 12:49 AM | #1 |
119
Rep 1,525
Will this Work?
I just did an AT to MT swap but getting a dsc code so my question is if i were to grab the dsc file from my donor car(MT) and install it into the swapped car(AT dme) can that be done?
2008 335i FFTEC ST 6266,), Boostbox, VRSF 3.5 exhaust, mtech front and rear, KWVll, APEX 18x9.0, 18x12= 305/35/18 NTO1s, BMS OCC, Rb PVC, M3 tri-color stitched S-wheel,MT SWAPPED, M3 LSD diff
2008 135i mods coming soon! |
10-21-2016, 09:35 AM | #2 | |
529
Rep 2,503
What code do you have? Likely DSC just needs to be reset with ISTA-D then steering angle recalibrated. |
10-22-2016, 10:16 AM | #3 |
119
Rep 1,525
pulling codes today, is the steering angle recal straight forward?
2008 135i mods coming soon! Last edited by 07tundra; 10-22-2016 at 07:58 PM.. |
10-22-2016, 05:09 PM | #4 |
529
Rep 2,503
First you'll have to recode car. Delete the $205 entry in your FA (VO) string then code to default the relevant modules.
Depending on what transmission you have installed you may need to add $206 (SMG) or $207. Double check this though. Use NCSEXPERT for the above. Then, if you have DSC faults use ISTA-D to run the service functions to calibrate steering angle sensor and adjust DSC. |
10-22-2016, 08:11 PM | #5 | |
119
Rep 1,525
I Cldnt find 207 but there is a 1207 is that the same ? Last edited by 07tundra; 10-22-2016 at 09:20 PM.. |
10-22-2016, 11:50 PM | #6 | |
BimECU
193
Rep 759
the error he has is somehow related to pt-can (errors on this screens are related to low battery, the error i mentioned is not shown here) but his pt-can connection is correct, so right now im out of ideas |
10-23-2016, 03:09 AM | #7 |
529
Rep 2,503
Hi,
So, these fault codes seems to all point to low voltage / battery problem. What is the voltage showing as with engine off? I recommend charging the battery now. Then clearing the codes. If as you say coding is correct then that's fine. So AT has been removed from VO and car codes to default? Also code DSC to default then perform the DSC service functions in ISTA. |
10-23-2016, 06:59 PM | #9 |
119
Rep 1,525
Guess what guys update everything is gone I have no codes at all no lights in the dash either!! Now the only problem is my Idrive is not responding radio works screen for idrive comes up i cannot move or select anything with button just fixed that also. Kris Looney my coder figured everything out cant wait to start having a little bit of fun
2008 135i mods coming soon! Last edited by 07tundra; 10-23-2016 at 08:19 PM.. |
10-23-2016, 08:34 PM | #10 |
119
Rep 1,525
Thank you Sensible for responding ! you too Levane for all your help
10-25-2016, 12:02 AM | #12 |
119
Rep 1,525
my coder figured it out so really i couldn't tell you but everyone was helpful so thank you again
