Oil change after deletes and stage 2+ tune..
10-19-2016, 07:23 AM | #1 |
38
Rep 144
Due for first oil change after mods and wanted to get an idea of what everyone is doing differently.
1) oil type? 2) oil filter? 3) interval? Also anything else you have changed on your service/maintenance. Thanks in advance! |
10-19-2016, 07:35 AM | #2 | |
57
Rep 210
1) oil type? Rotella T6 (I may try Delo 5ww-40 during the winter) 2) oil filter? WIX Filter 3) interval? 8,000 mile interval |
10-19-2016, 07:40 AM | #3 |
36
Rep 122
1. Liqui Moly Longtime
2. Mahle air filter 3. Planning on doing a change ~ every 7000-8000 miles. Do a search and you will find a few post on folks who have done oil analysis. If I remember correctly the oil typically still looked good at 10,000 miles, but that will obviously vary from car to car. |
10-19-2016, 08:18 AM | #5 | |
240
Rep 1,288
10-19-2016, 08:40 AM | #6 |
28
Rep 234
1. Amsoil
2. Mahle or OEM oil filter 3. Oil change every 8,000 miles 4. Mahle fuel filter every 30,000 miles. Air filter and cabin filter every now and then. |
10-19-2016, 08:56 AM | #7 |
111
Rep 529
Rotella T6
OEM filter every ~8000 k
2011 335d Deep Sea Blue on Beige (stock except for the cheap ass wheels from PO)
2010 328i Tasman Green on Saddle (stock) |
10-19-2016, 09:31 AM | #9 |
36
Rep 122
Once you do the deletes your options open up a little I believe, although the T6 may be ok even before the deletes, not sure. The reason I am using an LL-04 oil is because I still have my dpf.
kydiesel35166.00 |
10-19-2016, 10:05 AM | #10 |
Warrant Officer
375
Rep 1,341
T6 has been tested to be a good option. It's about $30-40 for 2 gallons so that's a good bonus.
Deleted, ATM I/C and tuned by B.R.R.
10-19-2016, 10:08 AM | #11 |
Rep 38
So what oil change method are you guys doing? On my old MKIV TDI I would do the top oil extraction method and put in a magnetic oil plug from ECS Tuning so any metallic particles would be taken out of circulation.
Also, anyone running a bypass filter? I am considering this where you never really change the oil. You just change both filters and add makeup oil to bring the level back up. Oil analysis can ensure the oil additives are good and nothing negative builds up. |
10-19-2016, 11:48 AM | #12 |
103
Rep 580
I run a Motorguard bypass on mine, but still plan to change at 10k intervals with T6 after the deletes are in. Top is visible in this shot, tucked in between the fender and rad hose:
Uber's Junk |
10-19-2016, 12:36 PM | #13 | |
57
Rep 210
10-19-2016, 02:20 PM | #14 |
103
Rep 580
10-20-2016, 08:44 AM | #18 |
171
Rep 504
Yes.
JR Auto tune and Bohl Diesel Downpipe - KWv2 coils - Apex Racing 18" EC7 wheels wrapped in Michelin PSS 245/275 F/R - Zimmerman cross drilled rotors F/R with Hawk HPS pads - SS brake lines - Motul RBF 600 - ADD W1 oil catch can - BMW performance CF spoiler
10-20-2016, 09:16 AM | #19 |
84
Rep 263
coming from ALWAYS using mobil1 in my gasers, it was really difficult to not use it in the d after the jr 2.5... I used the t6 however wonder if the mobil1 is better, same, or worse than the t6. can anyone provide any insight? the mobil1 in the gasers was tried and true with the cars earning well over 1xx,xxx mi. and 2xx,xxx mi. on one I dropped the engine for a look and it was spotless. thanks in advanced
10-20-2016, 09:56 AM | #20 |
Rep 50
what sort of certifications are needed for the oil? since the dpf is gone im assuming something with high minerals/detergents can be used, but is there a certain specification that still must be met?
10-20-2016, 11:18 AM | #21 |
83
Rep 432
DPFs don't like SAPs, as long as its removed use the highest quality you want to pay for. If you want to stick with BMW certs, I believe LL-01 is the qualification you're looking for, LL-04 is the same, but has low saps for emissions equipment (DPF still in place).
Depending on whats on sale, I use 0W40 oils for our cold weather. My DPF is removed as well. Mobil 1 0W40 (old formula meets LL-01, new 2016 Formula no longer certified. Doesn't mean it doesn't meet specs, its just not certified) Castrol EDGE with Fluid Titanium. EURO Formula. 0W40 (LL-01 cert) Redline 0W40 (They state suitable for LL-01 but not actually certified as it is expensive to receive certification apparently) I've read that Redline has the highest quality base stocks, and a healthy additive package with above average ZDDP. But it never goes on sale so I've been using Mobil 1 / Castrol EDGE FTT Euro as they are easily attainable locally. From what I've read, BMW uses Castrol EDGE Professional - European 5W30 OE as their supplier for BMW branded oil in these cars. |
