10-16-2016, 08:05 AM | #1 |
634
Rep 650
Check your factory alignment
I put about 250 miles on the car and wanted to check the factory alignment to establish a base for future tracking, the car also felt a little odd in the seat/rear. I took it to GTE in Atlanta, they do a ton of track cars, and it showed that both rear toe numbers were off (toe out) and the RR camber as well. After resetting the car feels better. If you went to the dealer with these settings they would tell you that you needed a $200 alignment! GTE said this is not unusual in that most new Porsches come in with off factory numbers.
10-17-2016, 07:28 AM | #3 | |
634
Rep 650
Yellowflash21369.50 BAN_M2C4176.00 |
10-17-2016, 12:23 PM | #6 | |
840
Rep 2,402
Are you looking at some other numbers? The right rear is clearly out of "factory tolerance" in both camber (no big deal) and toe. The factory-acceptable ranges are pre-loaded into the alignment machine, green means within factory spec, red means out. You would never want to run toe out in the rear of this car (sans perhaps a drifter). OP: Did you have a dead body in the trunk, by chance?
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) |
10-17-2016, 12:31 PM | #7 |
96
Rep 185
Something about a several thousand mile trip including over a rough ocean with the car winched down hard to the deck might do that Since you are having it done anyway, should do it with you in the car to make it even more accurate
10-17-2016, 01:34 PM | #8 | ||
340
Rep 310
Drives: 04A6 2.7T(DD), 16M2 BSM MT EP
When they swap the rear diff, something many 16-17MY m2's are in line for, the wheel alignment I believe is redone. I will ask for specs and printout. My rear diff is scheduled to be swapped out soon. |
10-17-2016, 01:46 PM | #9 | |
840
Rep 2,402
They should be able to drop the diff right out without removing the subframe (or any of the control arms attached thereto).
10-17-2016, 05:20 PM | #11 |
634
Rep 650
10-17-2016, 05:26 PM | #12 |
634
Rep 650
We did it both ways....toe was the still whack. Surprisingly, my extra 190lbs barely moved the needle....I think it was 1/10 on right camber only...very stiff suspension.
10-17-2016, 05:28 PM | #13 | |
634
Rep 650
10-17-2016, 06:39 PM | #14 | |
20
Rep 66
10-17-2016, 08:04 PM | #15 | |
340
Rep 310
When I find it I will post the link. |
10-18-2016, 01:11 PM | #16 | |
4449
Rep 7,594
Drives: '19 M2C
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange) |
10-18-2016, 08:13 PM | #18 |
634
Rep 650
10-19-2016, 02:47 PM | #19 |
BimmerPost Supporting Vendor
3812
Rep 54,307
Drives: F80 M3
Unfortunately that is not one of the checks they do at the port, but at the dealership level that should have been caught on a road test. Does the car pull to one side or the other?
10-19-2016, 06:19 PM | #21 |
634
Rep 650
10-19-2016, 06:20 PM | #22 |
634
Rep 650
