TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > 335d engine coolant temperature
      10-10-2016, 11:52 AM   #1
Owen81
83
Drives: 335d, 17/22 TDI
Heya,
I have a 2009 335d with Jarek 2.5 tune DPF/SCR removed and Andrew's EGR delete.
Now that its getting cold up here in Canada(-1°C this morning), I noticed my instant MPGs weren't quite where they used to be.
I opened torque and started monitoring the engine coolant temps, it seems that they hover around 72°C, getting up to around 78°C with some spirited acceleration but always coming down to around 70-72°C again.
I'm under the impression that our T-stat should operate at 90°C and this is where the coolant temp should be at during steady state driving, so my T-stat could be bad. I was just wondering if this would be the case, or if anyone else with the EGR delete has noticed their coolant temps being lower than normal?
Thanks
      10-10-2016, 12:08 PM   #2
335dM
128
Drives: 335d m package
86 degree
Your stat needs to be replaced!
      10-10-2016, 12:33 PM   #3
335dsleeper
389
Drives: 09' 335d 10'35D
Swap it. It's cheap and easy!
      10-10-2016, 01:10 PM   #4
Owen81
83
Will do! Any idea how much coolant I will need after the swap? I assume a lot is going to come out of the pump...
      10-10-2016, 02:26 PM   #5
BB_cuda
BB_cuda's Avatar
765
Drives: 2011 335D Msport, 2013 X5D
I recall losing a couple quarts. Just go buy the jug of coolant and mix 50/50. It might be time for you to do a coolant change anyway. I have it from a reliable source (Mike Miller) that it's every 2 yrs
      10-10-2016, 02:29 PM   #6
Poosik
23
Drives: BMW 335D
I also have Jarek tune (2.0). My temps never go over 81 degrees, just hover around 74-78.
Fuel economy also down
Does anyone have a DiY writeup for thermostat change?
Any recomendations on which one to get??
Thanks
      10-10-2016, 03:01 PM   #7
Owen81
83
Thanks
Do you have the EGR cooler delete as well?
      10-10-2016, 03:29 PM   #8
Poosik
23
Drives: BMW 335D
Yeah, EGR cooler is physically off
The inlet for EGR is plugged and throttle body that EGR connected to is replaced with a "race pipe" from ebay.
      10-10-2016, 03:43 PM   #9
Owen81
83
And you completed the cooling circuit with a line where the cooler would be like in this picture?
Photo courtesy of www.fixmyvw.com
http://cdn1.bigcommerce.com/server41...g?t=1462413336
I was wondering if this maybe provides a bypass for the coolant and that is why the temperatures are low?
      10-10-2016, 03:55 PM   #10
Poosik
23
Drives: BMW 335D
Yes, my coolant line is just like that.
The egr delete & coolant bypass were done about 2 months ago
The Jarek abc delete tune is about 2 years old.
That is when i actually started to monitor things with the obd2 dongle
My temps have always been in the range of 72-80ish
Rate of temp rise did not appear to change after egr coolant line was bypassed.
Good thought though!
I vaguely recall forum members writing up a diy for thermostat change.. also about installing a "higher temp" one...
      10-10-2016, 04:35 PM   #11
Owen81
83
Ah I see.
Looks like ours is very close to this DIY, and it should be much easier with the cooler out of the way!
http://www.e90post.com/forums/showthread.php?t=1008568
      10-11-2016, 08:09 AM   #12
dmanb2b
2125
Drives: G07, F97, F30, E90, E46, E30
Watching thread closely. Please let me know where you order t-stat from and if it solves the issue. With outside temp this am at 37F, coolant temp hovered at 76-78C.
      10-11-2016, 01:46 PM   #13
BB_cuda
BB_cuda's Avatar
765
http://www.bmwdirectparts.com/oe-bmw/11517805811
This is where I bought replacement T/S from. The above link already has the T/S loaded up for you. They used to be called Husker but it is still same dealer in Lincoln, Nebraska. Just a little over $50.
I have found it a good practice to throw in a couple oil filters, perhaps a fuel filter and other regularly serviced items to make the most of the shipping cost. I have a order in right now but one of the items has to come from Germany so it will take an extra week or so.
      10-11-2016, 04:26 PM   #14
dmanb2b
2125
Thank you!
      10-11-2016, 04:32 PM   #15
Persian Whisperjet
Kind of a Big Deal
167
Drives: 2011 335d
I got mine last month from ECS tuning for $55.95 including regular (slow boat) shipping.
      10-11-2016, 08:54 PM   #16
Poosik
23
Drives: BMW 335D
Just ordered the TS from ECSTunning. $50 ish & free shipping.
I will post update after install.
Today ambient temp in 40's and with coolant reaching MAX 74 deg after a 20mile drive. Mix driving.
Really hoping the temps improve.
      10-11-2016, 10:56 PM   #17
nicklockard
43
Drives: 2009 w/Nav; paddleshifters
Does anyone know about this higher temp t-stat thread? Where to find part? I'm very interested. Mine took 10 minutes of freeway driving to reach 78 Celsius today on a cool day (70's F). It would help fuel economy a lot.
Also: EGR cooler deletes always cost about 10% fuel economy hit in northern climates. Longer warm up times are also hell on engine wear.
      10-13-2016, 05:40 PM   #18
TDIwyse
614
Drives: 2011 335d
I had heard this as well. However, it has not born out on my vehicles. My Cummins doesn't have EGR, takes a VERY long time to warm up (unless pulling a load), and has had great UOA's along the many years of ownership.
My 335d showed improved mpg's (tracked every single fillup since new) and less wear on UOA's since doing the EGR delete, even though it takes much longer to warm up. And it rarely gets above 174F, unless very hot weather and running A/C, or doing multiple 1/4 mile passes in succession.
Some of the UOA's can be seen here: http://www.e90post.com/forums/showthread.php?t=1045534
I keep thinking about swapping the T-stat, but haven't measured a reason to fuss with it yet.
2011 335d 11.68 @ 125.71 mph 1/4 mile NHRA certified track
Ram Cummins with lots-o-mods
      10-13-2016, 05:59 PM   #19
kydiesel35
kydiesel35's Avatar
166
Drives: 2016 X5 35d
2011 BMW 335d  [0.00]
+1
      10-13-2016, 10:18 PM   #20
dmanb2b
2125
Sounds like I should drive more and worry less, maybe tackle t-stat next year?
      10-14-2016, 06:31 AM   #21
digitaldav
25
Drives: 2009 335d
Rockauto $39 plus shipping
https://www.rockauto.com/en/moreinfo...443058&jsn=276
      10-14-2016, 07:02 AM   #22
9mmkungfu
198
Drives: 335d, 535d, 750i, X5 35d
I'm also seeing temperatures in the 76-80 Celsius range. Should I be concerned?
