The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Check your engine mounts
      10-07-2016, 08:09 PM   #1
dixy2k
88
Drives: 335d
Took my car in for an unrelated issue. The shop advised me to replace the engine mounts, since both of them have collapsed.
I remember I had one replaced at the dealer a few years ago and never had them checked since.
2011 model, currently 116,700 miles.
Mik325tds805.50
      07-23-2018, 12:00 AM   #2
Chief Orman
Chief Orman's Avatar
671
Drives: 335D 2010
cost?
      07-23-2018, 12:31 PM   #3
Torqu3
321
Drives: 2011 335d
Originally Posted by Chief Orman View Post
cost?
About $250 for parts if you get both from FCPEuro. Labor is easy.
Appreciate 2
dmanb2b2124.50
Mik325tds805.50
      07-23-2018, 05:30 PM   #4
Mik325tds
Mik325tds's Avatar
806
Drives: 335d M-Sport
I wonder how they look when they are collapsed? I looked at mine the other day and thought they looked okay but wanted to do a vacuum test to make sure they hold vacuum.
      07-31-2018, 03:19 PM   #5
Dazza335iC
54
Drives: E39 M5, F15 35d
2000 E39 M5 Dinan  [0.00]
2017 X5 35d  [0.00]
What are the symptoms of faulty mounts?
      07-31-2018, 04:08 PM   #6
gavronm
88
Drives: 2011 335D M-Sport
Most common and obvious one is a grinding or rubbing noise from the front right corner of the car when accelerating hard while turning left. Many mistake it for wheel rub or a bad hub bearing.
E92.Dom64.00
      08-02-2018, 09:54 PM   #7
Miko226
Miko226's Avatar
61
Drives: 11' 335d
Increased vibrations are also a symptom
11' m57 335d 165k Miles - JR 2, ATM Full Exhaust & Intake, Wagner FMIC, AAR Boost Pipe, AAR Swirl Delete, AAR EGR Delete
08' n54 135i FBO E85 - SOLD
      08-06-2018, 03:11 PM   #8
PhotoGuy87
PhotoGuy87's Avatar
97
Drives: 11 M-Sport 335d, 11 E91 328i
When my 335d went in for a recall, the dealership told me that both of my engine mounts need to be replaced but I don't have any of the symptoms. No rubbing sound or vibrations.
mantis276.00
      08-06-2018, 10:31 PM   #9
rkstar9
75
Drives: '10 X5 3.5D
I am also very curious what a collapsed engine mount looks like.
535D Xdrive DUDMD Stage 1
x5d e70 DUDMD stage 2 tune
      08-07-2018, 10:06 PM   #10
BB_cuda
BB_cuda's Avatar
765
Drives: 2011 335D Msport, 2013 X5D
I wonder if they’re giving you a line? What is your mileage?
      08-09-2018, 06:40 AM   #11
PhotoGuy87
PhotoGuy87's Avatar
97
I'm currently at 95k miles but I bet it wouldn't be a bad idea to replace them when I do deletes since I am right there.
      08-10-2018, 08:02 AM   #12
rbreding
54
Drives: 328d, 335d, x5d
This. You will have one of them out already to perform the delete.
      08-12-2018, 09:08 PM   #13
awenthol
26
Drives: BSM 2011 335d
Replaced my passenger mount this weekend. Didn't know I was supposed to do both. It was collapsed...not easily identifiable without the two side by side and I didn't take any pictures. I had the "clicking when accelerating and turning left" issue.
      08-14-2018, 06:28 PM   #14
cm335d
59
Drives: 2011 BMW 335d
I'm expecting mine to look like that as well when I replace them this weekend. My car is making a noise on hard left turns. 109k on the odometer, so I suppose they are due. Just got a new set of engine mounts and trans mounts from FCPEuro delivered this afternoon. Can't wait to get my car back in shape.
      08-14-2018, 11:48 PM   #15
Evergreen24
Evergreen24's Avatar
Drives: 2011 335d M-Sport
If this was Momentum on Southwest Freeway, this is a favorite money maker of theirs. I'm not saying you don't need mounts, but I replaced mine, brought my car to them for other reasons and had them tell me they needed to be replaced again. I advised them that the mounts were already new, and they quickly backed off. On my next visit, I got the same line.
I imagine they'll also try to tell you that you need a new oil pan gasket at some point. That's their second favorite money maker. They added comments to two of my invoices "customer notes oil droplets in driveway" without my ever telling them such a thing... and then tried to sell me a new oil pan gasket on the third visit, after establishing a "record" so that they could attempt to submit a warranty claim.
The Houston dealers just don't know these cars--the indys are going to be much nicer to your diesel, in my opinion.
      08-15-2018, 12:15 AM   #16
cm335d
59
And that's why I'll always do my own service, unless its some free warranty or recall parts. I absolutely refuse to be shaken down.
      08-16-2018, 12:21 PM   #17
rkstar9
75
Drives: '10 X5 3.5D
scoundrels!
I highly doubt a "collapsed" engine mount is a thing.
I always thought the vacuum mechanism has an internal operation that does not raise or lower the mount at all. it simply increased or decreases dampening in a way that is not obvious by doing a visual inspection.
Unless a vacuum test was applied or a road test gives it away I don't see how that claim can be made.
      08-16-2018, 03:13 PM   #18
awenthol
26
Originally Posted by rkstar9 View Post
scoundrels!
Well sit back, because you're about to get schooled.
These are not your standard Chevy Cavalier engine mounts...these are very technical, multi-range engine vibration control device.
Cut off the end and you'll find the vacuum canister that does control the "preload" on the hydraulic damping system.
Go deeper and you'll open up the hydraulic chamber, complete with the fluid control "valving." Interesting that they're not using glycol and it's a very runny oil, so I'm going to guess that it's close to suspension fluid (I worked for one of the largest manufacturers of engine/trans/etc mounts, and we only ever used glycol in the fluid damper systems).
Go back to the top and you'll see the rubber has in fact collapsed about 10mm. Since I don't have access to a bandsaw and don't feel like cutting it down with a grinder at the moment, we're going to have to assume there is a quality issue/design flaw with the housing/rubber support that breaks. I will update when I cut the housing open (system is assembled and the aluminum is rolled over the rubber element).
Appreciate 5
      08-21-2018, 04:45 PM   #19
Mik325tds
Mik325tds's Avatar
806
Very nice awenthol! I like when people do investigative work and come around with qualified technical knowledge. If you can share any more technical insight on how these work, that would be greatly appreciated.
I took pictures of my mounts the other day and it looked like the right mount is a little lower than the left one but both still hold vacuum and are a little distance away from sitting on the rubber stops. My car is at 142kmiles
      08-25-2018, 01:37 PM   #20
Persian Whisperjet
Kind of a Big Deal
167
Drives: 2011 335d
Just had mine one (thanks Kevin at Aktiv!) at 113K. Irritating cabin vibration is now gone, car feels much "tighter."
      08-27-2018, 12:23 AM   #21
cm335d
59
Just replaced my motor and tranny mounts this weekend. Took about 4 hours total from start to bonnet closed and tools all put away. Here's a few links of the old vs new parts for comparison (new is on the left). The drive side mount was worn, but not riding on the bump stop. The passenger side, however, was shot and riding on the stop. This combination resulted in the increased vibration felt in the car, and very noticeable noise when taking hard left turns under power/speed. The old tranny mounts looked and felt fine to me, but I replaced them anyhow since I was there and had the parts on hand. They are only $7 each for the Lemforder tranny mounts anyhow.
Also replaced the vacuum lines, since I had the opportunity and the new factory vacuum line on hand.
The car is like new again. This project was worthwhile and yielded some satisfying results. My car has 109k miles on it by the way. If you're over 100k, I'd recommend looking at replacing your mounts soon.
Driver Side: https://photos.app.goo.gl/CAQkY1R3qHNMdVaX6
Passenger Side: https://photos.app.goo.gl/Ki6VvMJTyhC1HUAP6
Tranny Mounts: https://photos.app.goo.gl/VemxFyjHJjC8B9yL8
Appreciate 2
      08-27-2018, 02:33 AM   #22
banders
Drives: 2010 335d
just replaced mine today. So glad for the info on this forum. While under the car I noticed my struts are leaking so ill be upgrading those soon too. 95k miles.
