10-07-2016, 10:29 AM | #1 |
Bimmer Candidate
92
Rep 308
Engine/Transmission issue - need a diagnosis!
Hi all,
I have '16 M235i with about 9000 miles. Manual transmission. Drove perfectly until about 5000 miles, when one day when I went to drive it and I noticed something had changed. When I'm right at the transition point between throttle and no throttle (whether getting on throttle or coming off throttle), the car will sometimes noticeably hesitate and not transition cleanly. This is NOT only when I'm shifting gears - it can happen when I'm in a gear and cruising, giving it throttle or coming off it. The worst cases are when the car does a slight lurch, generally when coming off the gas. It's like a hesitation from throttle to no throttle where the car can't decide if it wants throttle or no throttle, and ends up sputtering between the two for a second, which results in a quick *bump bump bump* lurch before it comes completely off. Almost like what would happen if you pull out the clutch too quickly when downshifting. That same feeling. This doesn't happen every time. And when it's not happening, I can almost always feel a much more noticeable *bump* a half second or so after coming completely off the throttle, especially if I do it quickly. It's basically just not driving as smoothly or as cleanly as it did for the few few thousand miles. And I probably don't need to say that this is incredibly obnoxious. I'm generally pissed off when driving the car now because I can almost always feel these throttle transitions not happening cleanly. So I took it to the dealership under warranty, probably didn't explain it as well to them as I just did here, and had them check it all out. They couldn't find anything wrong, which is pretty much what I expected, unfortunately. What I need is a couple of possible specific things that it could be that I can tell the techs at the dealership, to focus the diagnostics a little better. Any possible culprits folks here can provide would be extremely helpful, for my car and my sanity. Thanks! |
10-07-2016, 11:31 AM | #2 |
715
Rep 1,541
I have an auto, but have had plenty of manual turbo cars before and can't recall that kind of issue in any of them.
Sorry I can't be of more help, but have you tried to duplicate the problem with the different throttle settings? Sport, Sport+, etc.... Only does it in certain gears? Certain speed? Half the process is just being able to duplicate the problem for the dealer.
10-07-2016, 11:31 AM | #3 |
5554
Rep 5,372
Any modifications? Have you played around with anything under the hood? Please be honest. It's the only way we can help you.
Which gears is this most noticeable? Is there a particular rpm range that this happens? Does it happen coming off of part-throttle, full throttle, or both? Does it happen in the first 5-10 minutes of driving or potentially anytime? Is there a thud from the chassis when it happens? If so, where does the sound appear to come from? How often is this happening? If you go back to BMW, it would be best to present them with a piece of paper describing the issue in detail. The tech will greatly appreciate it. |
10-07-2016, 11:44 AM | #4 |
3074
Rep 5,577
Ideally a flight data recorder to record the hesitation as opposed to going back in latter to pull codes - but that's up to the dealership.
If you look at the tach when this happens and if the tech stumbles at the moment it hesitates then you look at fuel system, if the tach very fast drops then electrical. Things you can do, change gas both brand and station. Do some sustained high speed and some high-rpm acceleration runs. Hopefully someone who really knows these drivetrains can answer better. |
10-07-2016, 11:44 AM | #5 | |
Bimmer Candidate
92
Rep 308
10-07-2016, 12:03 PM | #6 | |
Bimmer Candidate
92
Rep 308
Also, can I do my own flight recording? |
10-07-2016, 12:19 PM | #7 |
3074
Rep 5,577
You can't do the flight recorder data w/o the expensive computers.
About the electrical/fuel comparisons using the tach. If your car was stalling or dying while running. By looking at the tachometer the moment it stalls you can get a few clues: if it's fuel starvation as the fuel dries up while going to the injectors the tachometer will gradually drop to zero. If it's an electrical component that's turning of the engine the tachometer will quickly drop to zero - as quick as turning off a switch. Knowing that, if you view the tach while the car hesitates, a very rapid swing of the tachometer MIGHT mean electrical, like when you turn the car off. On the other hand if the tachometer needle drops or moves at a slowish speed like pumping a gas pedal then it could be fuel delivery or something fuel related like valve deposites. Did the dealer describe what kind of diagnostics they did, computer scan, search for loose piping around intake or turbo? But I don't know these particular cars very well, so I'm just telling you the kinds of things a driver can do to help clue into a solution. Last edited by overcoil; 10-07-2016 at 12:25 PM.. |
10-07-2016, 12:32 PM | #8 |
Bimmer Candidate
92
Rep 308
I haven't noticed the tach doing anything abnormal when it happens, but I also haven't been paying close attention. I'll keep my eye on it. The hesitation ("stalling" was a good word you used) is subtle enough where I'm not sure I'd see the tach move much anyway. It's not like the whole car nearly turns off. Just more like it's struggling to get all the way off throttle (or onto it).
10-07-2016, 02:59 PM | #10 |
715
Rep 1,541
Perhaps low rpm bucking.
10-07-2016, 04:36 PM | #11 |
5554
Rep 5,372
That's what I'm wondering. He's experiencing the issue on on/off gear throttle applications at near idle and below 2,000rpms. Those are pretty low operating rpms for a 3 liter motor when it's off-boost. I know these are powerful motors, but they lack the torque when off boost and are in a tall gear at low rpms. If don't downshift and simply keep adding gas, you start spooling the turbo and may put the motor into a dangerous high load, low rpm situation. Depending on conditions (cold/hot/muggy conditions or heat soaked motor), inducing a high load, low rpm situation can cause a big boost spike and the DME (ECU) may yank timing or abruptly kill boost to keep the motor from destructing from detonation. Automatics will "unlock" and slip the torque converter to compensate for the lack of torque or will downshift to keep from inducing a high load, low rpm situation.
I can feel a very minor drivetrain thud when letting off the throttle while in gear in 6th on the highway (rpms 2000-2500 or so) and I can feel something similar through the seat when I'm in a tall gear and running at a low rpms (i.e., below 2,000rpm). I notice it more now than I did when I first got the car, but I believe it's because I'm paying more attention to things after 7 months and 7K miles of ownership. I also understand that things have loosen up a bit in the drivetrain. I can't say this sensation/thud isn't uncommon to me though. My 2012 WRX 5MT did it, my 1996 Maxima 5MT did it, and all my prior manual Hondas did it. Some worse than others. What I felt was just the nature of operating a manual transmission at low rpms, the engine lacking some initial torque to overcome the load, and the drivetrain rocking a bit in its soft motor mounts. |
10-10-2016, 10:16 AM | #12 |
Bimmer Candidate
92
Rep 308
10-10-2016, 10:20 AM | #13 | |
Bimmer Candidate
92
Rep 308
10-12-2016, 08:09 AM | #14 |
Bimmer Candidate
92
Rep 308
This happened very noticeably again today. Cruising down the highway in some traffic, in 3rd gear, let off throttle, and just before I'd come completely off the throttle, at a little over 2000 RPMs, the engine sputtered/stalled a little before coming all the way back.
I was reading about throttle actuators and it sounds like a bad actuator could be a possible culprit. Any thoughts? Again, this doesn't happen consistently, so I'm not sure if that influences the answer. |
10-12-2016, 08:42 AM | #15 | |
3074
Rep 5,577
10-12-2016, 11:18 AM | #17 |
1425
Rep 3,395
10-12-2016, 11:30 AM | #18 |
Bimmer Candidate
92
Rep 308
In my original post I said that I'd taken it to a dealer and they were not able to find anything wrong. But I didn't describe it well at the time - I said that the engine was misfiring when transitioning between no throttle and some throttle, and that it had a rough idle. When I saw the advisor notes to the tech, it didn't mention the throttle piece, just that the engine was misfiring, so I don't think they took that into consideration during their check. And I've decided now that the engine could be idling roughly, but I'm not positive enough to say it out loud to a tech. I'd rather they focus on the things I know for sure.
So what I'm after is some possible culprits that I could take back to the dealer. Without those, they're just going to see if the car is throwing any codes (it's not) and call it a day. Do you have any ideas? |
10-12-2016, 11:32 AM | #19 | |
1425
Rep 3,395
10-12-2016, 04:20 PM | #20 |
Bimmer Candidate
92
Rep 308
It doesn't replicate often enough for that to work. And I did take it to the dealer and take it out with the shop foreman. It didn't happen on that drive.
10-13-2016, 10:22 AM | #21 |
Bimmer Candidate
92
Rep 308
What about my bad throttle actuator theory? Could there be a problem without the car throwing a code?
If you add up all the symptoms, throttle is the only consistent piece: - Throttle seems to engage too hard and seems to disengage too hard - Engine hesitation/hiccups/stalling at very low throttle, usually when coming off |
10-13-2016, 12:06 PM | #22 |
5554
Rep 5,372
The N55 does not use a throttle body under normal operations. The motor uses it's Valvetronic system to manipulate the valve timing and intake cam lift to adjust air intake volume. The motor does have a throttle body, but it's always fully open. Only if the Valvetronic system fails will the throttle body be used. I've never read of a Valvetronic motor failure causing an issue like this.
With respect to these "engine hesitation/hiccups/stalling at very low throttle, usually when coming off" issues, keep in mind that it is a manual thus a direct connection between the motor and transmission. If you're at really low throttle (sub 2000pms) and in the taller gear 3-6, releasing the throttle quickly and applying it somewhat quickly, can induce some stumble, hesitation, etc. especially if you're trying to use more than ~20% throttle. IMO, do not pay attention to the upshift indicator. It's too optimistic for a manual in many situations and can cause lugging. This is still a 3L motor with a turbo, not a high displacement V8 with a ton of torque down low. Sure, the N55 is a torquey beast, but only when the turbo is spooling. At low and part throttle, it's not spooling much at all (if any) thus far less torque is available. Getting on the throttle moderately or hard at a really low rpm can create a lot of boost and high load and flake out the DME. I strongly suggest using more elegant throttle applications at low rpms/high gear and to keep the rpms above 2000rpms when in gears 3-6, especially when approaching steeper grades. It's really hard to say what the issue is at this point because it's not happening all the time. It could possibly be: 1) The way you're driving (i.e., driving at too low rpms for certain situations and using too much throttle) 2) Simply the direct connection of a manual and movement drivetrain in it's somewhat soft rubber mounts. 3) A very tiny vacuum leak that becomes more pronounced has the motor rocks in it's mounts at lower rpms. The most common leak is at the charge pipe connection at the throttle body (driver's side of the motor, easily observable). Look at it closely and see if anything looks cracked or loose. Also look at the intake pipe joint connection at the front of the passenger side of the motor. 4) Fuel type. If you shop at the same gas station, perhaps consider a different station. 5) Bad coil pack or injector. This would be odd because you'd think the issue would be more pronounced under higher rpms and load and wouldn't make sense in an off throttle situation. I'd check all the intake piping has noted above, change gas stations, drive at slightly higher rpms (try and keep it between 2000-2500rpms) and consider plugging the negative battery terminal, technically resetting the ECU/DME. I'd also experiment with different driving modes and see if the car behaves the same way. If the problem persists, write a very detailed letter explaining what is happening, when, what it feels like, the driving situation, the gear(s), throttle application and amount of throttle given, ambient air conditions, etc. The more detail, the better. |
Tags |
engine, throttle, transmission |
