P02D0 - Cyl 3 Fuel Injector Offset Learning at Min Limit
10-04-2016, 11:00 AM | #1 |
74
Rep 1,689
Does anyone have any idea what specifically causes this code?
Like what parameters would trigger the DDE to throw this code? Jarek flashed the latest DDE version to my car along with a tune. Adaptations were done but the code persists. The injector is brand new and has been coded to the car. I don't have warranty and can't really afford to endlessly throw injectors at the car so I was wondering if there's anything else I can do to clear this code. Can anyone point me in the right direction?
2010 BMW 335d "Ha! She wants the D."
2006 VW Jetta 2.5 Once upon a time... '03 VW GTI, '99 Audi A4 1.8TQ, '00 VW Jetta 1.85T, '09 BMW 335i xDrive, '04 BMW Z4 3.0i, '01 Audi TT 1.8T, '04 Volvo S80 2.5T |
10-04-2016, 11:18 AM | #3 | |
74
Rep 1,689
I cleaned it out when I first bought the car, but was unable to get behind the valves very well as I don't have the walnut shell cleaning tools. Did the best I could with a shop vac, engine degreaser, and a set of picks. I'm really curious what the DDE conditions are for that code to get triggered. Is it a fuel flow thing?
10-04-2016, 09:40 PM | #5 |
171
Rep 504
JR Auto tune and Bohl Diesel Downpipe - KWv2 coils - Apex Racing 18" EC7 wheels wrapped in Michelin PSS 245/275 F/R - Zimmerman cross drilled rotors F/R with Hawk HPS pads - SS brake lines - Motul RBF 600 - ADD W1 oil catch can - BMW performance CF spoiler
10-05-2016, 06:27 AM | #6 |
38
Rep 144
I had this and many other codes such as NOX sensor etc when my DPF started to get clogged. After my delete and BPC stage 2+ all is well. Did you do the deletes? If not I would measure your spot mass etc which can easily be done in Carly. Good luck!
10-05-2016, 12:49 PM | #7 |
74
Rep 1,689
Deletes are done in software. Only thing left to do is swap out the exhaust which will be done this weekend.
10-05-2016, 04:10 PM | #8 |
213
Rep 2,210
I had the misfortune of running the delete tune without deletes for a few minutes and got a couple random codes as well. I would ignore it unless you get the same codes after the deletes. How far have you driven since the tune?
10-27-2016, 11:18 AM | #10 |
Rep 14
My 2011 with 65k had rough idle for a couple of weeks and then the threw a p02D0. It only ran rough below 1500 rpm. I kept driving watching for poor mileage or I low power. BPC recommended swapping 3 injectors. I took a spirited drive over some mountains on Saturday and the code as well as the rough idle are gone.
It seems to me to be a software bug in the DDE. I may have to have the DDE reprogrammed or replaced one day. Last edited by TN335d; 10-27-2016 at 05:09 PM.. |
10-27-2016, 11:42 AM | #11 |
806
Rep 1,191
Here's what ISTA has to say for that fault code:
Fault description: Zero-quantity adaptation monitoring. The fault is set if the following preconditions exist at the same time: - The corrected activation duration of the injector at one of the 3 calibration points drops below the minimum activation duration. - The deviation at one of the 3 calibration points drops below the minimum limit value. Condition for fault identification: Depending on the operating point. Control unit voltage: 9.5 V to 16 V. Condition for fault memory entry: The fault is entered if it has been detected more than the following number of times (fault debouncing counter): 1 Action in service: Replace fuel injector Fault effect and breakdown warning:None Driver information: Malfunction indicator lamp Service instruction: If an injector is replaced, the following service function must be carried out: Injection quantity compensation. |
10-27-2016, 11:14 PM | #12 |
Rep 3
i had the same code but on cylinder 2.. ran through 10 gallons of diesel with a can of bg244k in it and reset the injector adaptations with ista-d and its been gone now for almost 4k miles
10-28-2016, 07:47 AM | #13 |
Rep 3
Has anyone tried LiquiMoly's product "Diesel Purge" for this issue and ran directly to fuel line? I am having same injector code only 300 miles after running GREAT with my new stage 2 JR tune, iaknown's downpipe and egr plates. Have not gutted the SCR yet. Could SCR already be clogged and causing the issue? Would trying the diesel purge cause any harm, or maybe someone has had good luck with this helping what seems like a minor injector miss?
Any advice appreciated! |
10-31-2016, 06:28 PM | #14 |
171
Rep 504
Almost 4 years back when i got the car, and it was stock, it got rough idle the first winter. I put almost a bottle full of amsoil diesel kleen + cetane boost, and it went away. It never had any injector codes though.
10-31-2016, 07:04 PM | #15 |
277
Rep 1,575
i think our injectors do not like the winterized fuel. I drove up to Washington state and once I filled up in Washington, I was having an unstable cold idle. once I filled up after leaving the state. 2 tanks later. gone.
