E90 amp
10-03-2016, 05:05 PM | #1 |
392
Rep 2,367
Drives: 2011 335i
E90 amp
What channel is e90 amp
10-03-2016, 05:25 PM | #2 | |
1905
Rep 6,968
The logic 7 amp has 7 channels I think. There are 2 amps out there that are better than the Harmon-Kardon amp. JBL MS-8 And Rockford Fosgate 360.3 But you need to keep the head unit and re-locate it in the rear portion of your car in order for an after mkt amp to work, if you have the logic 7 amp. |
10-03-2016, 05:28 PM | #3 | ||
392
Rep 2,367
Drives: 2011 335i
10-03-2016, 07:41 PM | #4 |
1918
Rep 13,115
There is an entire BMW stereo board sub forum
right here. http://www.e90post.com/forums/forumdisplay.php?f=27 you will find details on the three main bmw stereo systems in these documents BMW stereo types http://www.e90post.com/forums/showthread.php?t=352586 http://www.e90post.com/forums/attach...2&d=1266451970 http://www.e90post.com/forums/attach...2&d=1260829447 http://www.e90post.com/forums/showthread.php?t=343673 http://www.e90post.com/forums/showthread.php?t=138949 http://www.e90post.com/forums/attach...1&d=1209780605 http://www.e90post.com/forums/attach...1&d=1209780865 http://www.e90post.com/forums/showthread.php?t=641323 http://bmwcoders.com/forum/3-er-8/bm...1-e92-e93-291/ http://technicpnp.com/menuDiagrams/d...e90_92_93.html http://www.musicarnw.com/page-2/ http://www.e90post.com/forums/attach...4&d=1278871872 If you are thinking of modifying or substituting after market amps . It can be done fairly easily with the stereo and hi fi system but not the L7 as described in the above documents. ms-8 is no longer made rockford 360.3 is a dsp not and amp. stereo system head unit power 4 channels Hi fi 6 channels amp is weak Logic 7 9 channels connected to the idrive or radio by fiber optics not easy or inexpensive to modify. current popular modification helix 82dsp from bimmertech and a set of aftermarket speakers for the fronts if you have stereo or Hi Fi. Last edited by ctuna; 10-04-2016 at 07:32 PM.. |
