SCR Catalytic Replacement
09-30-2016, 10:00 AM | #1 |
60
Rep 245
Hi All,
The "SCR Functional check" says that I have to replace the SCR catalytic converter, I even bought one for replacement, and visited the mechanic, but guy who is doing welding works told me that I have to check everything one more time because he can't believe that 2011 car needs the replacement, by his explanation "bad" cat is cat full of soot, but my car runs great and it means that cat is clean. Usually car looses it's power when cat is full of soot. One of his idea that there is something else can tell to the Engine ECU that can leads to cat, but it is definitely not a cat. What do you think about that? |
09-30-2016, 10:22 AM | #2 |
765
Rep 3,556
There is a cat within the DPF called a DOC (diesel oxidation catalyst). There is a different cat in the SCR. It is an ammonia reactor to scrub the NOx. Briefly, urea is heated up to then convert to ammonia. The ammonia reacts with SCR bed and exhaust gases to make GN2 and water, reducing the NOx output.
You need to be careful how you are interpreting the cat info. If normal DPF is in place, the SCR shouldn't be getting sooted up. The DOC will see soot. The welder is using a viewpoint more on the gasoline engine front. |
09-30-2016, 10:27 AM | #3 | |
60
Rep 245
09-30-2016, 11:06 AM | #4 |
765
Rep 3,556
Firstly, talking to wrong guy about running system testing. Clarification also in that DPF "container" has DOC in front and diesel particulate filter in the aft section.
Floydrogers is pretty knowledgeable on this front. Hopefully, he'll be along soon to offer input. |
09-30-2016, 04:09 PM | #8 |
60
Rep 245
I don't know who is Floyd, but I hope he can clarify this situation. I will replace the cat at the end of next week probably and will collect the ideas and opinions till that point. Thank you.
09-30-2016, 04:29 PM | #9 |
213
Rep 2,210
Did you test out the nox sensors? Cant remember if you tried that. The DDE uses nox sensor feedback to determine if the SCR cat is good so if a nox sensor is bad you can get a false positive on the SCR cat being bad. A clogged DEF metering valve causing low flow or poor spray pattern could also cause a false positive on the SCR cat.
09-30-2016, 04:42 PM | #11 |
213
Rep 2,210
Well, replacing them with good ones works. You can also try switching their positions and see if the code changes, but since you got new ones id say its not likely to be them. Only other thing to check would be the metering valve flow and pattern. If thats good...
09-30-2016, 06:26 PM | #12 |
24
Rep 196
Your test showed only a 41% NOx conversion rate - since the NOx sensors are new OEM - right?, metering valve is dosing the correct amount, DEF is new then your SCR catalyst is the cause as the test indicated. Usually it is an aging sensor(s) or metering valve issue....
With a new SCR catalyst > 90% |
09-30-2016, 07:37 PM | #13 |
60
Rep 245
09-30-2016, 07:39 PM | #14 |
60
Rep 245
I bought front sensor new and rear used from car with 60k miles on odometer. I guess I can replace it again with new one and replace the metering valve just in case if they are not good enoght
10-03-2016, 10:15 AM | #15 |
60
Rep 245
Typically I have to erase the "SCR system inefficiency" error every day on\after my way back from home, but this weekend I decided that probably I have to wait few more days and see what happens, probably another codes will appears, but after 3 days and about 200 miles I still have only one code... 4D16 SCR System, efficiency, does anybody have any other ideas instead of replacing the SCR Cat? Should I check something else before? Thanks.
10-03-2016, 11:20 AM | #17 |
Rep 33
Had the same code last year. I can't remember if there were other codes. Dealer replaced scr under warranty. Metering unit wasn't covered for some reason. I replaced the metering unit myself.
10-03-2016, 11:33 AM | #18 |
60
Rep 245
10-03-2016, 11:38 AM | #19 |
60
Rep 245
10-03-2016, 03:01 PM | #20 |
213
Rep 2,210
10-03-2016, 03:14 PM | #21 |
60
Rep 245
Tags |
catalytic, diesel, scr, soot, welding |
