09-29-2016, 12:41 AM | #1 |
Administrator
40712
Rep 21,238
World Debut of BMW X2 Concept
BIMMERPOST NEWS World Debut of BMW X2 Concept The BMW Group has chosen the Paris Motor Show 2016 to present the BMW Concept X2. This new addition to the compact segment has a distinctive design that stands apart from that of the other X models and also draws on the BMW Group’s history of coupe-making. The result is a compact concept exuding urban sporting appeal. “The BMW Concept X2 is a vehicle for active people looking for a combination of enjoyment and practicality,” explains Adrian van Hooydonk, Senior Vice President BMW Group Design. “The concept displays a new and exciting facet of the BMW brand within the compact segment.” The design – a successful blend of dynamic appeal and solidity. The design of the BMW Concept X2 fuses apparent contradictions into a single coherent statement. “The BMW Concept X2 combines the fast-moving body language and low-slung proportions of a coupe with the robust construction of an X model. This is a sporty vehicle with a bold character, and it allows us to open up some fascinating new design possibilities for the BMW brand,” says Karim Habib, Head of BMW Design. The distinctive character of the BMW Concept X2 already shines through in the car’s proportions. While its large wheels and familiar two-box design underline its functional X model character, a long wheelbase, stretched roofline, short overhangs and heavily forward-slanting C-pillar give the body a sporty, low-to-the-road feel. The interplay of the darker cladding surfaces and striking Luminous Red body colour make the Concept X2 look even slimmer from the side. Two facets to a singular character – the side view. The upper section of the car’s flanks is dominated by sporty design elements. The elongated roofline and slim window graphic create a stretched feel. The glasshouse tapers towards the rear, forming an athletic shoulder section. The window graphic surrounds and integrated two-piece mirror bases (both made from brushed aluminium) add an extra touch of class. The thickness of the aluminium profile plays a contrasting role here. The window graphic is rounded off by a dynamic interpretation of the hallmark BMW Hofmeister kink. Like the logo on the C-pillar – a classically sporty coupe design cue straight out of the BMW history books – this represents a singularly unmistakeable detail. The large, air-channelling roof spoiler in body colour lies flat over the blackened rear window. Extending from the C-pillars, it gives the rear of the BMW Concept X2 its sporty contours. Lower down the sides of the car, customary X-model features hog the limelight. Muscular surfaces, large wheel arches and stylistic underfloor protection around the door sills form an intriguing contrast with the dynamic elements further up. Focusing for a moment on more detailed features, the surfaces of the car’s flanks bring together large, smoothly modelled sections with precise edges, showcasing the car’s athletic presence. The dramatic surfacing also emphasises the almost squared-off wheel arches familiar from the car’s BMW X stablemates. In them sit large, 21-inch light-alloy wheels, whose striking, double-spoke, bi-colour design with a strong sense of three- dimensionality continues the contrast between dynamic appeal and solidity into the car’s details. Tyres with chunky treads point to the potential for fun off the beaten track, while door sills in body colour with integral hexagonal elements set the seal on the robust appearance of the car’s sides at their lowest point. Dynamism and presence – the front end. The front-end design of the BMW Concept X2 likewise fuses dynamic elements with a robust use of forms. Clearly contoured volumes and subtle edges create a front-end impression with presence and sporting appeal in abundance. The heavily raked windscreen appears to extend seamlessly into the dark panoramic roof and teams up with the newly interpreted double kidney grille and large air intakes to give the front end a slow-slung look. The kidneys are sited a little lower than the headlights, and the central air intake is closer to the road than the two outer intakes. This makes the centre of the car appear lower, underlining the dynamic verve of the front-end design. The kidneys turn the familiar trapezoidal shape of BMW grilles on its head and instead widen from top to bottom. This clear statement therefore accentuates the standalone nature of the BMW Concept X2, as well as the width of the front and the car’s solid stance. Graphically modelled and heavily angled bars within the kidney grille create an undeniable “shark nose” effect, bringing additional depth and sculptural richness to this area of the car. The flat contours of the headlight tubes help to give the classical BMW twin circular look a more hexagonal form. The laser light technology used by the headlights enables very slim light graphics, while the blue X in the centre of the hexagonal tubes adds a further technical accent. The front apron is dominated by the large central air intake below the kidney grille, which helps to quench the Concept X2’s thirst for cooling air. The smaller, triangular air intakes on either side highlight the car’s broad stance. The robust, horizontal slats of the air intakes provide a solid counterpoint to the dynamic design of the front apron and add further detailed emphasis of the front-end’s traditional X-model character. A powerful statement – the rear end. The rear of the BMW Concept X2 rounds off the exterior design in distinctive style. Width-accentuating elements such as the slim rear window and horizontal lines reduce the perceived height of the BMW Concept X2 and underscore its sporting pretentions. From this angle you can also see how the rear window emerges elegantly from below the air-channelling spoiler and underlines the car’s sporting character. The prominent tapering of the glasshouse along the sides of the Concept X2 also catches the eye. It forms a powerful shoulder area, allowing it to highlight the car’s broad, muscular stance. Below the glasshouse, the sharply drawn rear lights radiate dynamic intent. The fresh interpretation of the lights’ familiar “L” shape frames the LED element as an illuminating three-dimensional sculpture that projects from the rear to eye-catching effect. Located between the rear lights is the BMW logo. Below, the almost uninterrupted transition from tailgate to rear apron creates a cohesive overall picture which spotlights the car’s crisp surface language with particular clarity. The dark cladding below the rear apron lifts the whole rear end visually, while at the same time giving its upper section a slimmer look. The body-colour rear apron provides a dynamic flourish to round off the lower reaches of the rear. A large tailpipe at either outer extreme emphasises the car’s broad stance, while the surrounding surfaces reference the three-way split and overall form of the front air intakes. Reveal Video Karim Habib, Chief BMW Designer, Discusses Design |
09-29-2016, 06:01 AM | #2 |
Moderator
7509
Rep 19,370
Wow, I really like where this is headed.
Makes the GLA look frumpy, and I actually like the GLA for its quirkiness. But this X2 looks downright sexy, at least in concept form. Only thing I'd nix is the "barnacle butt" exhaust outlets, but that probably won't make production anyway. Now, they need to give it the right stuff under the hood. That's the one piece where I fear disappointment may await. GLA45 is up to 375hp now, and while I know that kind of power is not happening for the X2, we aren't even sure the M35i will be over 300hp. Audi also throws it down in this segment with their I5 (not the new all aluminum one yet, but it will come next generation) in the Q3 RS. Though that one isn't sold in the US, the next one surely will be. BMW needs to commit to the high performance transverse powertrain like these two are. If you are going in, go all in. |
09-29-2016, 06:03 AM | #3 |
1535
Rep 4,555
I love it! I hope the roundel on the rear sides doesn't make production version
Current: 2021 ///M3 Competition Isle of Man Green
Ordered: 2024 ///M2 Zandvoort Blue Past: 2018 X3 ///M40i | 2012 328i | 2009 335i | 2007 335i Coupe | 2005 545i | 2001 325i Last edited by Zirenz2006; 09-29-2016 at 06:15 AM.. |
09-29-2016, 06:04 AM | #4 |
209
Rep 470
I don't understand this segment but this looks amazing.
09-29-2016, 06:17 AM | #7 |
1535
Rep 4,555
Not coming out until Spring 2018....damn
@SCOTT26 I thought you said it would be out second half of 2017?
Ordered: 2024 ///M2 Zandvoort Blue Past: 2018 X3 ///M40i | 2012 328i | 2009 335i | 2007 335i Coupe | 2005 545i | 2001 325i Last edited by Zirenz2006; 09-29-2016 at 06:23 AM.. |
09-29-2016, 06:28 AM | #8 |
10779
Rep 27,588
pretty cool looking..so many models now!
09-29-2016, 06:29 AM | #9 |
1144
Rep 891
Drives: None atm
Brutal all i have to say i wonder how the M package will look on this
CQVD33051.50 M3 Adjuster7904.50 |
09-29-2016, 06:31 AM | #10 |
66
Rep 79
Undoubtedly this is a good looking vehicle but it doesn't look like a German car and it certainly doesn't look like a BMW.
It's unfortunate that BMW has lost its edge in design and innovation. Instead they want to copy Mercedes and Audi in their pursuits to manufacture more Asian looking vehicles every year. As a German, I can tell you we love minimalism and a clean design. Germans love a sleeper that doesn't give off its hand right away. This vehicle looks cheap and loud like an attention seeking girl at a club with 10lbs of make up on and sequins and glitter all over.
F13 650i M Sport Space Gray/Vermillion Red "Gisele" |
AtlantaDude128.00 DrtyJrze707.00 larryn2145.50 C1Boston103.00 TommyGuk327.00 Law6379.00 domriley14.50 c63er876.00 cjack29.50 6MT_Addict283.00 RENT-A-GOAT461.00 |
09-29-2016, 06:50 AM | #13 |
263
Rep 337
Drives: '17 M2 DCT BSM
Ugly AF!
09-29-2016, 06:53 AM | #14 | |
763
Rep 5,560
The final product will not be so extravagant, I hope we'll see it with a shadow line trim! |
09-29-2016, 06:56 AM | #15 | |
763
Rep 5,560
09-29-2016, 06:58 AM | #16 | |
32
Rep 145
09-29-2016, 07:05 AM | #17 | |
Driver
465
Rep 1,002
09-29-2016, 07:08 AM | #18 |
Rep 9
09-29-2016, 07:15 AM | #19 | |
1535
Rep 4,555
Ordered: 2024 ///M2 Zandvoort Blue Past: 2018 X3 ///M40i | 2012 328i | 2009 335i | 2007 335i Coupe | 2005 545i | 2001 325i |
M3 Adjuster7904.50 bradleyland1503.50 |
09-29-2016, 07:24 AM | #20 |
52
Rep 284
Drives: 2017 340i MPPSK
Omg!!!!!
09-29-2016, 07:24 AM | #21 |
567
Rep 635
I really like it. Love the fact that it is so different to the X1 everywhere. That's how it should be done one the X3/4 and X5/6. Nice job.
Now, for production form it's easy. Take the X4 concept and compare to the production car. That's probably what will happen with the transition of this concept to the road aswell. Let's see if the interior though. Hope it departs very far away from the X1's, which its just laughable. |
09-29-2016, 07:25 AM | #22 |
4972
Rep 10,200
Drives: 2024 Golf R / 2022 718 Spyder
Looks less like what I thought it would - not sure if I like it or not...the headlight assembly looks like it has been pushed too far away from the center of the car and towards the quarter panels IMO.
Side profile isn't bad...definitely needs a drop and bigger wheels. Back end reminds me of a Japanese car that I can't place...funky design but wondering how this fits into the overall lineup. EDIT - no interior photos?
Past rides: 2016 981 BGTS, 2020 MINI JCW, 2017 F80, 2015 981 CS, 2014 F22 235, 2011 E82 135, 2008 E82 135, 2007 E92 328, 2007 E92 328 (My lady drives an OG M2. So does my dad)
