M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Hard Wired Dash Camera .. VERY Easy
      09-25-2016, 09:37 PM   #1
Chuck W.
Chuck W.'s Avatar
356
Drives: '95 Porsche 993 Cab
I have a dash cam in every car I own (4) and 3 of the kids cars. All are BlackVues. I hard wired both a dash cam and a radar detector in my 2012 535I F10. One I tapped into the mirror and the other I tapped into the overhead console. The mirror is much easier.
I used shawnsheridan posting on another forum to install the F10s. When I opened the rear view mirror's housing on the M2 (very easy) I found the same the 10-Wire Connector Plug inside it. The +12V (Switched off the ignition) on the Brown/Green wire and Ground on the Brown/Black wire.
I used the wire taps and fed the wire at the top of the mirror housing. Good to go.
2022 X5 40I - Ours
2016 BMW M2 LBB 6 Sp / ED Pick Up on 07/12/2016 - Her's
1995 Porsche 993 Cab - Mine
2001 Toyota Tundra SR5 Ext Cab - Hay Hauler
Appreciate 3
BAN_M2C4180.00
3Si216.50
      09-27-2016, 01:06 PM   #2
zenmaster
1577
Drives: '17 M2
How many days can the parking monitor be powered by the car's battery?
      09-27-2016, 01:17 PM   #3
Chuck W.
Chuck W.'s Avatar
356
I am not sure. I have mine hooked up to turn off when the car's ignition is turned off. There is a product "Power Magic Pro" that can be used with the camera and set up to turn off after the battery reaches a certain voltage level and motion activated.
2022 X5 40I - Ours
      09-28-2016, 05:12 AM   #4
zenmaster
1577
Drives: '17 M2
I'd definitely want my cam recording the motion-detect events while car is parked. Would be a shame to lose that feature.
      09-28-2016, 05:48 AM   #5
Prodigy.
Prodigy.'s Avatar
Australia
698
Drives: ///M2
Mine is hardwired using the power magic pro. I have it set to turn off after 12 hours however you can set it stay on indefinitely.
I do find though that mine generally shuts down after about 8hrs due to the battery voltage dropping too low, my car is generally not driven daily though so that probably doesn't help with the battery's charge.
      09-28-2016, 04:48 PM   #6
zenmaster
1577
Drives: '17 M2
Can you put a 5v Li Ion battery pack in line with it? That should last days.
      09-28-2016, 06:54 PM   #7
Ex-MINI
BMW Newb
Ex-MINI's Avatar
582
Drives: 2016 LBB M2 DCT
You don't want to be storing a large LiON battery in a hot car....that's why most dashcams these days use capacitors...
      09-28-2016, 09:24 PM   #8
Prodigy.
Prodigy.'s Avatar
Australia
698
Drives: ///M2
You can purchase one of these:
http://www.autoblackbox.com.au/acces...-battery-pack/
      09-29-2016, 08:24 AM   #9
Shankska
Shankska's Avatar
411
Drives: 2019 BMW M2 Competition
2019 BMW M2 Comp  [0.00]
2016 BMW M2  [0.00]
2014 BMW M235i  [0.00]
what dash cam did you purchase for this install?
2019 F87 M2C, Long Beach Blue, Exec, 6MT
2016 F87 M2 - Sold 9/2018
2014 F22 M235i - Sold 5/2016.
      10-04-2016, 10:36 PM   #10
Chuck W.
Chuck W.'s Avatar
356
All of the dash camera I use are BlackVues. The one in the M2 is a Blackvue DR650GW.
2022 X5 40I - Ours
      10-26-2016, 06:25 PM   #11
3Si
3Si's Avatar
217
Drives: 16 M2, 16 Macan S, 08 Elise SC
Just installed one today. Thank you for the reassurance that it was easy as I'm mechanically challenged. I did it without using the mirror housing, I just hid the line through the top part of the housing then inside the lining all the way to the back. Used the cigarette outlet at the back and done. Can't believe the store was going to charge me $400 to do the installation... Damn thieves told me they do it professionally and will warranty their work...
Appreciate 2
Chuck W.356.00
      10-26-2016, 06:38 PM   #12
LeonTheJeweler
LeonTheJeweler's Avatar
34
Drives: m2
What u use it for
IG leonthejeweler
New Jersey
      10-26-2016, 09:54 PM   #13
3Si
3Si's Avatar
217
Originally Posted by g force View Post
What u use it for
To take a video of people backing up to me, then claiming I rear ended them. And the occassional WW flash during track days.
      10-27-2016, 03:53 PM   #14
TXSurfer
TXSurfer's Avatar
99
Drives: 335i E92
Whats the difference between 650gw and 650s?
      10-27-2016, 05:54 PM   #15
Chuck W.
Chuck W.'s Avatar
356
Here you go...
https://www.blackvue.com/dr650s-seri...es-comparison/
2022 X5 40I - Ours
      10-27-2016, 06:06 PM   #16
TXSurfer
TXSurfer's Avatar
99
Drives: 335i E92
Here you go...
Thanks ordered my camera!
      10-27-2016, 07:11 PM   #17
Chuck W.
Chuck W.'s Avatar
356
Cool. I hope it never comes in handy for you! (That means you'll never have an issue while driving). With all of the road rage and bad drivers out there I look at it as an extra level of security. It takes any doubt out of most situations.
2022 X5 40I - Ours
      10-27-2016, 07:15 PM   #18
TXSurfer
TXSurfer's Avatar
99
Drives: 335i E92
Exactly why I wanted one. To many aggressive drivers out there. Better safe than sorry.
      10-27-2016, 07:19 PM   #19
TXSurfer
TXSurfer's Avatar
99
Drives: 335i E92
Curious what size storage did everyone go with? I ordered 64gb.
      10-27-2016, 09:00 PM   #20
Chuck W.
Chuck W.'s Avatar
356
I have had issues with the mirco SD cards that come with the units. I usually swap them out for a SanDisk 64gb card. I always keep a spare in the glove box in case of a SD card failure.
2022 X5 40I - Ours
      10-27-2016, 11:16 PM   #21
zenmaster
1577
Drives: '17 M2
I use a transcend 128GB
      11-05-2016, 06:44 PM   #22
TXSurfer
TXSurfer's Avatar
99
Drives: 335i E92
Anyone wire the 2ch one yet. Got in mine but now thinking of sending it back and getting the 2ch version for front and rear.
m2
