09-23-2016, 09:16 AM | #1 |
3074
Rep 5,577
6-spd box fluid change at dealer
For my second service at 17K mikes I asked the dealership to change out the manual gearbox fluid. I swear the gear change is smoother then before. I'm curious if it's due to a different fluid. Maybe it's all in my head but it really feels better.
Curious if anyone else had noticed a difference with gearbox fluid change. |
09-23-2016, 11:13 AM | #2 |
287
Rep 864
Temp and Fluid DOES MATTER
I'm my old E90 I did use the expensive MT fluid from BMW; however, I changed to the Redline MTL which is lighter and it did make things a little smoother. I achieved my smoothest changes when I did the CDV (CLUTCH DELAY VALVE) delete - which restricted fluid and therefore protected the transmission during a potential clutch dump. I wonder if BMW still uses this valve.
. . After the switch to MTL and the CDV elimination -- my dealer was amazed and the techs thought it was the best shifting E90 they had driven. . |
09-23-2016, 12:20 PM | #3 |
3074
Rep 5,577
Yeah I did a cursory search few weeks back and don't think there is a way to delete the CDV.
But wow, when a manual shifts smooth - there is absolutely no notchiness |
09-29-2016, 08:50 AM | #4 | |
45
Rep 46
Or was this covered under maintenance warranty? |
09-29-2016, 09:05 AM | #5 |
3074
Rep 5,577
09-29-2016, 09:18 AM | #6 |
1L
156
Rep 336
I don't know if I want my notchy feel to go away. It must be when I had my E39 540 that I really liked the feeling. It gives me that reassurance its in gear. Is the the notchiness completely gone Scott?
2015 Glacier Silver M235i/6MT
MP Front Splitter//MP CF Short Shifter//MP CF E-brake//MP LSD//Cold Weather package//Driver Assistance package//Oyster Dakota leather//Aluminum Hexagon trim//ECS Tuning Wheel Spacers//AutoPlus Rear Diffuser//HUD//Rexing DashCam//AutoID M Mirror Caps |
09-29-2016, 09:46 AM | #7 | |
3074
Rep 5,577
I had no complaints before the change, just though fresh gear oil would mean draining out any wear particles from new. Could be my imagination but I don't think so, I really thought the fluid was updated and different. |
09-29-2016, 01:01 PM | #8 |
583
Rep 1,117
Drives: 2015 BMW M235i
I wanna do this (along with lsd fluid flush) but I don't know if I should do it before or after winter storage.....argh!
09-29-2016, 01:47 PM | #10 | |
3074
Rep 5,577
And my dealership does great work, never scratches the car, no test drives. Had new tire's put on at same time and no scratches on wheels and lugs torqued to spec. I often do maintenance myself and think the labor price was fair particularly for a dealership. Now I didn't know the fluid type and going price on-line, but it was cheaper then the fluid in my old Mercedes automatic. |
10-31-2016, 10:12 AM | #11 |
289
Rep 556
For example in a few years ago in California:
Stevenscreek BMW (San Jose) $210.88/flathour Mountainview BMW (Mountainview) $195/hour Fremont BMW (Fremont) $198/hour |
11-16-2016, 11:34 AM | #12 |
3833
Rep 2,870
I've seen other posts mention that they put break in additives in trans and diff initially, so the new stuff probably is different, even if the actual base oil is the same.
And FWIW they also charge $200/hour here in North Podunk NY - I guess I can look at the bright side, and consider myself to be living in an affluent area (are there 'low rent' BMW dealerships?). Our local place also comps you the KY for the first 4 years . |
01-17-2017, 07:05 PM | #15 |
90
Rep 351
would I be crazy to want to do the trans fluid swap myself? I did it on my rx8 no sweat, however I am well aware that my 2er is a much different beast. anyone ever done it before? know of a diy for an f22?
01-18-2017, 07:42 PM | #17 |
463
Rep 957
it is no big deal, drain then fill, just remove shields like for oil change and one more back.
01-20-2017, 07:09 PM | #18 |
157
Rep 580
There is no drain plug so you need a fluid extraction pump,but that is no big deal. BMW lifetime fill,you know. Then just refill.Youtube is your friend.
01-23-2017, 08:19 AM | #19 | |
90
Rep 351
My thoughts on BMW Lifetime fill: 1. Why swap M car trans fluid but not non-M? 2. Every other car manuf. swaps trans fluid- calling general bullshit on BMW black magic |
02-13-2017, 03:21 PM | #21 |
308
Rep 647
02-16-2017, 04:43 PM | #22 |
90
Rep 351
Hey guys! So I have a 228 and ordered MTF LT 5, but I believe my recommended oil is MTF LT 3. I can't find 3 anywhere online.
Should return the oil and try and get LT 3? Are there differences? What are they? Thanks for the help! -Chris |
