09-18-2016, 09:50 PM | #1 |
F36 440i Gran coupe
21
Rep 81
Cruise control malfunction repeitive error code
Hello mates, I am asking regarding to a 'cruise control malfunction' code that constantly comes on and off randomly. When the code comes on the only noticeable thing that occurs is that the steering wheel buttons dont work after the error is on, but... Once it goes away randomly ether in couple seconds or a min time span, the steering wheel buttons operate and everything is normal again..
Looked all over and couldnt get info smh... , looking for help please haha. Thank you for reading and have an great day! |
04-05-2017, 03:07 PM | #3 |
54
Rep 341
It's your switch steering column. I had the same issue but it's not random it can be reproduced under certain angle of your steering wheel. Dealer fixed the issue by replacing this http://www.realoem.com/bmw/enUS/show...diagId=61_2982
The dealer told me it had shorted out. I think it's just a faulty part. |
04-08-2018, 01:19 PM | #4 |
AutoPilot
97
Rep 87
Drives: 19 X1,18 M550i,15 X5,14 328d
Garage List 2011 Mercedes GL550 [0.00]
2019 BMW X128i [0.00] 2015 X5 XDrive35i [0.00] 2018 M550i [0.00] 2014 328d [0.00] |
Same issue here... Do you have a part number? The link goes to the Main Page for F30 - not a particular part.
04-23-2018, 03:18 PM | #5 |
Rep 2
Good to know I'm not alone. Same issue here. Taking it to the dealer.
The annoying thing is that the message disappears before I can read any codes, still trying to catch the code but it's still very random. |
02-16-2019, 04:01 PM | #8 |
109
Rep 152
I just started seeing this after swapping steering wheels. It pops up, goes away, and everything works as normal.
I'll put the other wheel back on to see if it is related to something in the wheel. EDIT: Found this thread https://f80.bimmerpost.com/forums/sh....php?t=1383004 GOing to swap the innards of my old wheel, and see if that fixes it. Just trying to install paddles Last edited by mclark2112; 02-16-2019 at 04:09 PM.. |
03-28-2021, 10:08 PM | #10 |
Rep 6
I'm having the same issue on my 2014 328i. Whenever I turn the wheel, the code goes away and the buttons on the wheel work again. The malfunction happens randomly and usually at slower speeds.
03-29-2021, 08:43 AM | #11 |
814
Rep 1,597
I had cruise control intermittent failures and button lights go off. Replaced the wiring harness and everything is fine. This seems to have been a problem since the e-series.
01-14-2022, 01:17 AM | #12 |
Rep 12
01-14-2022, 12:18 PM | #13 |
814
Rep 1,597
