09-15-2016, 12:51 AM | #1 |
146
Rep 350
Stupid Mistake - Disconnected Battery
Excuse me for being stupid this one time. As I'm writing this I'm patiently waiting for my flight. I won't be returning to my vehicle for 6wks. So I thought what a great idea it would be to disconnect my battery so it dosnt die. Well I realized that when I get back I have no way of getting in my trunk without power. No key hole on the trunk-No way to put the seats down cause the latches are in the trunk. Button doesn't work without power. Soo I'm guessing that my only option is to pop the hood assuming that works without power and jump the car from the engine bay..
I'll deal with this when I return but for now wanted to hear the best solution and to put this out there for others. Although I may just be the only one that didn't think this through |
09-15-2016, 01:31 AM | #4 | |
146
Rep 350
I drive a 2015 M235i. |
09-15-2016, 10:11 AM | #8 |
4338
Rep 6,196
09-15-2016, 01:37 PM | #10 |
3788
Rep 5,776
Good idea...I never knew that was what that is.
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP |
09-15-2016, 05:10 PM | #11 |
813
Rep 1,575
put your key in the key hole and twist. the keyhole is next to the pad you press to unlock the trunk from the outside.
2.0l ecosmackkaa
09-15-2016, 08:44 PM | #13 |
The Cool Guy/ You're drinking' Buddy
175
Rep 107
09-15-2016, 09:01 PM | #14 | |
813
Rep 1,575
2.0l ecosmackkaa
09-15-2016, 09:05 PM | #15 |
Moderator
7515
Rep 19,368
You should be able to flip down the ski pass-through and, using the glow-in-the-dark emergency release handle, open the trunk. If you are small enough you might be able to actually climb through to access it. But if not then you could reach your arm through, or perhaps use a clothing hanger or other makeshift tool to grab onto it.
Now, I am not personally familiar with the F2x 2 Series, so I am making the assumption that the pass-through is similar to the 3 and 4 Series. I am also making the assumption that you don't have a ski bag installed which would block the passage. |
09-15-2016, 09:07 PM | #16 |
Moderator
7515
Rep 19,368
09-16-2016, 12:22 AM | #17 | |
146
Rep 350
To my knowledge there is no way to access my trunk with out power. No key hole to my knowledge on my trunk. The only way to release the back seats is a lever inside the trunk. |
09-16-2016, 12:28 AM | #18 |
146
Rep 350
09-16-2016, 12:47 AM | #19 |
1144
Rep 892
Drives: None atm
Guys you don't need to disconnect the battery to let the car sit..... I had my 2er stored away from 1st of November to 1 of april during the winter time here in Sweden it started without a problem, Otherwise you have a faulty battery.
09-16-2016, 04:04 AM | #20 | |
310
Rep 886
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/BimmerTech amp, Enhanced BT
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi |
09-16-2016, 06:55 AM | #21 |
4338
Rep 6,196
09-16-2016, 07:30 AM | #22 |
FDNY Engine 55
681
Rep 2,115
Just get 1 of these https://www.ecstuning.com/News/Schwa...eight_Charger/
I bought 1 for all 3 of my trucks and it will start a dead battery in seconds no matter how drained the battery may be. You can also use it to charge iPhone, iPad's etc.
FDNY ENGINE 55...Liberalism: Find a Cure...http://www.xbimmers.com/forums/showthread.php?t=1127923
