Coding changes not working
09-13-2016, 01:37 AM | #1 |
Rep 40
Hi there,
I am trying to change my radio frequency from Japan to Europe so that I can receive the normal frequencies here in NZ. I installed BMW Coding Tools as per the DIY on here (thanks a lot for this!), and everything seems to work correctly - I am trying to adjust the following: CHOST ------------------------------------------- LAENDERVARIANTE_GT from "japan" to "ece" CTUNE ------------------------------------------- RDS_AF_FUNKTION_CCC set to "rds_ein_af_automatisch" LAENDERVARIANTE_TUNER_ANT from "japan" to "ece" CAPPL ----------------------------------------- LAENDERVARIANTE_TUNER from "japan" to "ece" The problem is that the changes just don't seem to stick. When I read the modules again, the values are back to the original as if nothing happened. Any help is hugely appreciated. F. |
09-13-2016, 11:38 AM | #2 |
BimECU
193
Rep 759
Looks like you are using wrong profile in NCSExpert,
you should use profile that has MAN manipulation enabled usually names contain "MAN" in the name like "Expert MAN" or smth like that |
09-13-2016, 04:23 PM | #3 |
Rep 40
Thanks, I'll give it a go when I get home. On a side note, those modules seem to be available regardless of whether I choose the CAS or FRM computer, is that weird? I haven't looked in NFRM yet but does it matter where I make those changes?
09-13-2016, 06:36 PM | #4 |
BimECU
193
Rep 759
its just two modules thru which you connect to other modules
doesnot really matter which one you choose, CAS is default |
09-14-2016, 02:55 PM | #5 | |
Rep 40
Thanks for the help. F. |
