09-10-2016, 04:04 AM | #1 |
39
Rep 137
Where is this oil coming from
So I have noticed as of late a build up of oil in some weird places coming from what looks like the inside the underside of the hood. I don't think its blow back coming through the intake. I hope not if so I would need to put a catch can. But from what I was told the N55 does not have this issue. There is no real way to describe this take a look at the pictures. Has anyone experienced or seen this before on the 235?
09-10-2016, 07:43 AM | #2 |
3074
Rep 5,577
Normal corrosion protection oil spreading over the metal.
Maybe it's engine and ambient heat that makes it occur as the mileage increased. But it's normal and there are a few other post about this. Last edited by overcoil; 09-10-2016 at 08:03 AM.. |
09-10-2016, 11:52 AM | #6 |
454
Rep 986
I have the same oil buildup from the hood. Initially noticed it around the top left corner of my front/right headlight.. It started accumulating there, and congeals again over the top part of the lens to a yellowish color.. Gross. It takes some elbow grease to clean, and it keeps coming back unfortunately. 2 years, 33,000 miles it still happens.
09-10-2016, 12:53 PM | #8 |
308
Rep 647
99% sure this isnt motor oil. It is called cosmoline and it is used to protect the metal against corrosion while shipping. If you look harder in the engine bay you will see it in other places as well. Its ok, dont worry.
09-10-2016, 12:56 PM | #9 |
243
Rep 447
I have this too, I believe it is grease for the hood closures. I think as things get hot under the hood it starts to breakdown a bit can come out under the hood. I've had it, others have had it, pretty sure another post on this somewhere. Not engine oil and not coming from the intake as it really couldn't come from the intake as the engine is upstream of that and your intake filter would be saturated in oil if that were the case.
'15 M235xi | BSM/Oyster/Aluminum | Black Kidneys | RW Carbon Mirror Caps | 40% tint
09-10-2016, 04:19 PM | #10 |
39
Rep 137
Either way it's nasty and is making a mess. That's a hell of a lot of cosmoline. Should it not be staying where it was applied to prevent corrosion. At this rate it will not have protection much longer. Anyhow thanks for the info guys much appreciated.
