2010 2011 BMW 5 Series Forum F10 F10 Headunit to Amp Wiring Description |
09-09-2016, 01:42 PM | #1 |
1105
Rep 1,607
Drives: 2020 M8 Comp First Edition
Hi, I have JBL MS-8 installed with technic harness and for highs and kicker CX300.1 for subs. Couple of days ago subs stopped working even though the both amps are on. I checked the fuse no issues. Only thing I could narrow down to was if I increase the gain on kicker to 80% (where it used to be on 40%) and indash base to 90% I would get sub working again but on higher volume then before.
Only thing I could think of is either ms8 channel 6-7 output is giving extremely low signal suddenly or kicker cx300 input signal has gone bad. I wanted to see if I could tap directly into the sub output wires coming from head-unit bypassing the ms8 and see if that makes a difference. Let me know any help would be appreciated as I can't figure out which wire to tap into need some help with description. 2013 535i Hifi Thx
GT
2020 BMW M8 Comp First Edition 2019 Panamera Turbo 2021 BMW X6M Comp 2019 BMW M5 2018 Maserati Ghibli SQ4 GranSport |
09-09-2016, 08:49 PM | #2 |
1105
Rep 1,607
Figured out the issue. Ms8 channel 6-7 rca output wasn't giving enough signal. Tapped into wires from technic out put harness for sub everything good now. Much stronger signal.
GT
