Stumbling Idle
09-07-2016, 11:37 PM | #1 |
Rep 21
Stumbling Idle
So this just started on Thursday and I'm kind of at a loss on what to do next. I already replaced the MAP sensor, decarbon the intake manifold and throttle body replaced coils and plugs... Any help would be appreciated. Thanks
09-08-2016, 10:40 AM | #5 |
Rep 21
09-08-2016, 11:15 AM | #6 |
232
Rep 642
Drives: 2010 E92 335i
Is it a rough idle? Does the engine shake erratically when it does that? I had a similar thing happen to me and it was bad injectors.
09-08-2016, 11:46 AM | #7 |
Rep 21
No it's not a rough idle. It sometimes corrects itself if i let it idle for a while. It got better when I replaced the coils and spark plugs but it's still there. Very annoying when sitting in traffic or next to a mustang at a red light thinking I'm trying to race him. No misfires under full throttle pulls like a champ just the idle is driving me nuts.
09-08-2016, 12:16 PM | #8 |
ST
Rep 23
Have you tried reading codes?
I have a Schawben scan tool that is capable of adaptation resets. Located in Downey also. Last edited by alpin3d3vil335; 09-08-2016 at 12:22 PM.. |
09-08-2016, 01:05 PM | #9 |
105
Rep 544
09-08-2016, 02:52 PM | #11 |
Rep 21
09-08-2016, 02:55 PM | #13 |
Rep 21
Never stalled it almost wants to shut off though but it catches itself and eventually smooths itself out. It pulls hard through all gears and after pushing it hard it will idle fine for a bit and then the idle starts to stumble. It's never consistent either the stumbling will start very light, get heavy then light again and if left sitting long enough it will fix itself
09-08-2016, 03:31 PM | #14 |
ST
Rep 23
PM me.
09-08-2016, 03:36 PM | #15 |
964
Rep 3,854
Drives: 330i, 135i
check for vacuum leaks. Maybe something is not back in place. hoses etc...
any codes? |
09-08-2016, 06:07 PM | #16 |
Rep 21
09-08-2016, 06:54 PM | #18 |
964
Rep 3,854
Drives: 330i, 135i
The problem is that even if they get one they wont know how to use it...
10-19-2016, 06:17 PM | #20 |
Rep 21
Throttle body map sensor replaced, map sensor on the piping was cleaned, fuel pressure regulator replaced still having the idle problem. anything else that I'm missing?
10-19-2016, 08:01 PM | #21 |
30
Rep 142
I had the exact same problem. Its the injectors. I was not getting any codes either. After i got 6 new index 12 injectors and got them coded, the problem was fixed.
10-20-2016, 09:39 AM | #22 | |
Rep 21
