09-07-2016, 04:13 PM | #1 |
241
Rep 307
How do I get paint off my tires?
On my way home from work today I unsuspectingly drove through a can of fresh paint that must have fallen off a work truck.
Luckily I was able to pull over so it didnt fly all of my car, but all my tires look like this. I tried to preasure wash the point off as soon as I got home but it didnt really budge. Is there anything I can do at this point? 3rd day I've had the car |
09-07-2016, 06:49 PM | #6 |
267
Rep 554
The Stable
2015 BMW M235i | 2014 Porsche Carrera S | 2017 Porsche Macan GTS | 1996 Porsche Carrera 4S |
09-07-2016, 06:51 PM | #7 |
241
Rep 307
09-07-2016, 07:03 PM | #8 |
267
Rep 554
The wheel wells will prove to be more difficult to get right. I had something similar happen and I used a solvent to get it off the wheel well liners. In fact, carb cleaning spray from AutoZone worked great.
The Stable
09-07-2016, 10:46 PM | #9 |
110
Rep 393
Please be careful with carb cleaner.. That can damage organic clear coats and paint, and some plastics.
A good pressure wash will take care of most issues with wheel wells and build up.. |
09-07-2016, 11:29 PM | #10 |
5554
Rep 5,372
Looks like the front tires are depicted. I'd go find some turns with wide shoulders (because you'll understeer at first) and roast that paint off. It won't stand a chance with thousands of pounds of force pushing against it.
Rear tires? A few quick burnouts will get rid of it. |
09-08-2016, 10:03 AM | #12 |
289
Rep 556
For the wheel wells go to Home Depot or Lowes paint department and get a box of Trisodium Phosphate (TSP).
Fill a bucket with 1 gallon of hot water and add 1/2 cup of TSP. Apply it with a stiff bristle wheel cleaning brush to the wheel well plastic. If you splash any of it on a painted surface wipe it off immediately (it may stain the paint). Let it sit for a few minutes rinse and repeat if necessary. Now there may be a few spots that the TSP didn't remove on the plastic wheel well liner. For that use some critrius based paint stripper like CitriStrip Carefully apply it to the stubborn spots on the plastic wheel well liner and let sit for 10-15 minutes. If you get some CitriStrip on any painted surface wipe it off immediately, it is not strong enough to remove automotive paint but it may stain if left on for a while. Good Luck |
09-08-2016, 01:27 PM | #15 |
4516
Rep 8,942
You could also call your local body shop. Tires don't worry about them that will take care of itself, but wheel wells I am sure they could clean up quick. My mother once got yellow line paint from freshly painted dividers on her car and my guy took care of it no problem. If yours could do it quick for even $50 maybe worth doing that as opposed to buying stuff, spending your time doing it and dealing with the toxic fumes, etc.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
09-08-2016, 01:45 PM | #16 | |
241
Rep 307
09-08-2016, 05:05 PM | #17 |
Lucky13
211
Rep 1,762
True story, had a rental car in San Francisco 30 years ago and was driving to Carmel with my wife and best friend. On the way somehow a fresh can of paint was in the road and covered half the lower side of the drivers side. My buddy says let's try some paint remover (some pot may have been involved) so we stop at a store put it on with a rag and bam most of the paint on the lower half of the car peels off. I had a morning flight home so we decided to take the car back the night before and cover the sides with mud so they wouldn't notice.It was the only dirty car in Northern California but it worked and I never got a bill or a call about the damage.
1995 325i, 1996 328ci, 1997 528i, 1997 Z3 2.8, 2000 528i, 2001 X5 3.0, 2001 330i Convertible, 2002 M3 Convertible, 2003 M3 Coupe, 2004 M3 Coupe, 2004 Z4 3.0, 2004 X3 3.0, 2007 X3 3.0, 2007 335i Convertible, 2013 X1 28 sdrive, 2014 M235 manual, 2020 X3 30i Xdrive
