car is leaning to either side!
09-07-2016, 01:32 AM | #1 |
18
Rep 216
So I recently put an m3 steering wheel on my car and my car started leaning to the right-hand side which is quite noticeable. Then I took my car in for an alignment and the mechanic said that my left front, right front, and left back camber is non-adjustable. He said someone might hit the curb while driving the car and I do not remember I hit anything. He said something might be damage (forgot if he was talking about the camber or the struts ?. After the alignment, I can see that my left front wheel is slightly pointing left when I put my steering wheel in the center, the right front wheel is pointing forward straight. Does anyone know what is causing the problem of my car is leaning to either left or right. I have the alignment result below.
This is killing me |
09-07-2016, 03:48 AM | #2 |
4542
Rep 11,903
You have to be careful to replace the steering wheel in the exact same spot as when you took it off. There is a sensor plate behind the wheel and if the steering wheel is off center when you replace it, you will get the offset problem you describe... Turn the wheel until the front tires are straight, remove the steering wheel and put it back on in the correct position. Hopefully this will fix the problem
This wont of course help if one tire is straight and the other one is pointed in a different direction, that can only be fixed by a wheel alignment |
09-07-2016, 09:31 AM | #3 | |
3829
Rep 4,667
Drives: BMW
That's what I remember when swapping for the sport steering wheel. Last edited by TheBingoBalls; 09-07-2016 at 10:14 PM.. |
VTECaddict481.00 |
09-07-2016, 09:40 AM | #4 |
380
Rep 1,497
When I swapped mine I put a black mark in the middle of the teeth and oem wheel and when I removed it I made sure the new wheel center was on that tooth mark. Works perfectly fine and got a proper alignment as well
09-07-2016, 10:55 AM | #5 |
18
Rep 216
I installed the steering wheel twice. I tried to put the wheel into the center and turns out theres only 1 angle that i can put the wheel in, which is the center. When I put the screw and locked the wheel, it makes the wheel turn to the right side. (not only the wheel, but the whole sgeering column).
09-07-2016, 02:55 PM | #6 | |
43
Rep 358
The front has an alignment pin near the strut tower bolts that has to be removed or drilled out that allows for some camber adjustments.
2006 e90 330i | Black/Terra | 6MT | ZSP | ZPP | ZCW
09-07-2016, 02:58 PM | #7 | |
3829
Rep 4,667
Drives: BMW
Hopefully someone here with more alignment experience knowledge can chime in. |
09-07-2016, 07:57 PM | #8 |
Where'd my VTEC go?
481
Rep 6,067
Something is very wrong with your front camber.
A steering wheel swap wouldn't cause any of that. Maybe someone borrowed your car and hit a curb? There is only one possible way it can go on.
09-07-2016, 09:17 PM | #9 | |
18
Rep 216
This happens after I changed my steering wheel. But as I said, I installed the steering wheel twice and made sure that the center of the wheel is on the mark of the steering column and if I am off, I could not even put the wheel in. Last edited by wallacelau; 09-07-2016 at 09:36 PM.. |
09-07-2016, 10:17 PM | #12 |
3829
Rep 4,667
Drives: BMW
You probably can, but the car's geometry (aside from the front camber) is where it should be so if you can see one tire or wheel pointed straight or any direction and it's not the same on the other side, something else is bent or out of position. Both your toe and steering wheel position is aligned perfectly.
09-07-2016, 10:50 PM | #13 | |
18
Rep 216
09-07-2016, 11:05 PM | #14 |
3829
Rep 4,667
Drives: BMW
Like I said in an earlier post, if your front camber is out of alignment, good chance that your struts are bent. You can slightly adjust it by removing the alignment pins but it's not going to "fix" your camber issues. But generally speaking, there are slight ways you can adjust the front camber but if it's not to spec, something is bent, likely the struts.
09-07-2016, 11:09 PM | #15 | |
18
Rep 216
thanks dude |
09-07-2016, 11:31 PM | #16 |
3829
Rep 4,667
Drives: BMW
09-09-2016, 12:02 AM | #17 |
18
Rep 216
I just got my car back today. I had my mechanic checked my suspension system but he said nothing is bent. He said my alignment was not good and thus my tires weared unevenly. Last time the shop aligned my car but it felt bad. This time, he found another mechanic to align my car and its way better. Not really leaning to neither side (maybe just a bit but it is barely noticeable).
Good news! |
09-09-2016, 12:11 AM | #18 | |
428
Rep 707
09-09-2016, 12:17 AM | #19 |
18
Rep 216
what do you mean?
I had the car aligned last week and it was terrible after that. I sent in my car on Tuesday for oil leak issue and asked him to do it again for me. He told me he gave my car to another mechanic (different from the guy who aligned my car last time). He said he realized my car is a "higher level" car (maybe he meant its more complicated), so he chose a better mechanic. I was like WTF. LOL So everything is solved now. |
