Read 1B file app
09-04-2016, 06:26 AM | #1 |
Rep 4
Read 1B file app
this week i updated my cic to pro. and i asked the guy to get me the map update code, and to download the 1b file he used one app called "SWT to FSC" if i'm not mistaken, basically the app uses the method of ftp but is fully automatic. He used an usb to ethernet connected to the usb on the glove compartiment
1. Get a ENET cable (yes, even though e9x doesn't normally use ENET). These typically end up costing about $5 by the time you pay for shipping and everything, but you can certainly save some money by making your own. Search eBay for "bmw enet", see this example for pre-made cables, or make your own with these instructions. 2. Set your PC/Android/Mac ethernet port to IP: 169.254.199.98, subnet: 255.255.255.0, Gateway: 169.254.199.99, any DNS 3. Connect the cable and turn on the car (acc mode is fine) 4. In your web browser go to: ftp://169.254.199.99 5. It should prompt for a login, user name is "root", password is either "Hm83stN)" or "cic0803" 6. Click the link to go up a directory a couple of times then browse to /HBpersistence/normal and download the file "generalPersistencyData_DiagnosticSWTControlle r" 7. Disconnect from the car and get that file into Windows 8. Open the file in a hex editor like Hxd http://mh-nexus.de/downloads/HxDSetupEN.zip 9. Press CTRL-F to search, change the search mode to "Hex" and then search for "01 01 00 1B”. Note that the data just before this should read "3F 01 00 00", otherwise see 9a below. 10. Highlight and delete everything prior to "01 01 00 1B” 11. Go to line (offset) 130 and delete the last block and everything after. The data to be deleted should begin with "3F 01", otherwise see 11a below. 12. Save the file as "a.hex", which should be exactly 319 bytes i cannot find it anywhere online. anybody knows any app that do this? |
