BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Wheels + Tires Sponsored by The Tire Rack
  TireRack
KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK!
      03-30-2008, 02:08 AM   #1
lebreeze
162
Drives: 18’c63s,15’macanturbo,14’ 991s
2008 e92 m3  [0.00]
comes w/ runflats ?
I was just wondering if the new m3 came with runflats. My CA told me today that it did. I am from canada so i dont know if our m3 did come with runflats. In the brochure it says there is a runflat indicator so does that mean there is runflats?
lebreeze
      03-30-2008, 02:11 AM   #2
gorun
gorun's Avatar
45
Drives: W166 ML63 PP
Dont think it does
      03-30-2008, 02:24 AM   #3
dangoma
Your Mom
13
Drives: 2008 M3
CA's are stupid.
Mine said that the car did not come with a spare cause the car had runflats.
Um talk about not knowing what he is selling.
I clearly corrected him and made him feel stupid.
      03-30-2008, 02:46 AM   #4
lvwirelessguy
30
Drives: 2011 E92 M3, 2012 Golf TDI
2005 M3  [0.00]
///M cars do not come with run flats thankfully!
      03-30-2008, 03:17 AM   #5
kbk_75
India
24
Drives: Alpine White E92 M3
The M3 does not come with runflat tyres. It does have a tyre pressure monitoring system. I've had my tyre pressure monitor indicate a puncture three times in four months, when, in fact, there wasn't one. IMHO, what's happening is that the system alerts you when your current tyre pressure drops beyond a certain percentage of the pressure you "set" the tyres at.
In actual fact the system is not measuring tyre pressure at all, but tyre rotation speed, if I'm not mistaken.
      03-30-2008, 04:17 AM   #6
lvwirelessguy
30
2005 M3  [0.00]
The E92 M3 has Direct TPMS, an easy way to tell is by the solid metal valve stems
I believe all 07 and newer BMWs have Direct TPMS
Older cars had Indirect TPMS which measures the air pressure indirectly by monitoring individual wheel speeds and other signals available in the vehicle
      03-30-2008, 04:30 AM   #7
Tallest
Tallest's Avatar
1279
Drives: 911
2011 911  [10.00]
in europe, my car for sure, doesn't have anything in the wheels, the tmps is in ABS unit i think, just measuring circumference of the wheels and the difference between, and if its alarming.. you get an alarm.
F30.F11.E86.E90.E90.E36
      03-30-2008, 04:36 AM   #8
OzStriker
OzStriker's Avatar
Australia
61
Drives: Ford Falcon Ute, Ducati 1198S
There is a bit of wrong info here.
The E92 M3 comes with either FTM (Flat Tyre Monitoring) or TPM (Tyre Pressure Monitoring).
In Australia we have FTM which as has been mentioned above simply measures change in wheel diameter through a change in wheel RPMs. You need to reset this each time you change the pressure in the tyres, the car does a short reinitialisation over a few metres and uses this wheel diameter to detect any change if a tyre deflated.
TPM is standard in the USA as it is mandatory in all new cars over there, and has been since September 2007.
BMW E92 M3 6MT, G-Power SKII supercharged, custom exhaust with 100 cell cats and Remus Sport mufflers, Brembo 380mm BBK, BMW Performance steering wheel, LUX H8 angel eyes, CF CSL boot, Hamann CF diffuser, Vorsteiner CF lip, CF grilles, CF gills, CF bonnet vents, BMW Performance stripes, RAC RG63 wheels, Eibach lowering springs, camber modifications.
      03-30-2008, 06:32 AM   #9
kbk_75
India
24
Oz, quick question, how often do you check and "reset" your tyre pressures? Have you faced a false alarm Tyre Puncture warning with your car?
      03-30-2008, 07:26 AM   #10
mkoesel
Moderator
7506
Drives: No BMW for now
Anyone know why they chose to put a TPMS button on the dash for the M3, vs. having it only available via iDrive (or the dash computer for non-iDrive) in the normal 3 series? Is it just because they had an extra button with the DTC button gone, or is there something special about the M3 TPMS that makes the button necessary?
      03-30-2008, 07:41 AM   #11
OzStriker
OzStriker's Avatar
Australia
61
Well I check pressures weekly I suppose...No false alarms. In reality you only need to reset it if one tyre gets seriously deflated, but good practise to reset each time you check pressures.
      03-30-2008, 08:02 AM   #12
Gearhead999s
Gearhead999s's Avatar
812
Drives: RR Velar R=Dynamic M2C R1200GS
I beleive the Canadian cars come with the FTM not the TPM.I know 100% that my wifes 335 w 19's came with FTM and I am thankfull for that as I did not have to bother with sensors on her snow tire package and as I have a track setup coming for the M at least I do not have to bother with the sensors.
      03-30-2008, 10:14 AM   #13
ersin
ersin's Avatar
124
Drives: 17 YMB F80 M3
No runflats for the M3. The other 3 series come with runflats standard. I believe all new cars must have a tire pressure monitoring system of some kind by federal regulation. I do not know details of this regulation. Maybe with runflats you do not need the pressure monitoring.
2017 F80 YMB.
      03-30-2008, 10:26 AM   #14
mkoesel
Moderator
7506
As OzStriker pointed out, all cars sold in US must now use TPMS. This is regardless of whether the car has runflats or not.
Many (most?) regions of the world only require the simpler FTMS, which BMW actually prefers for it simplicity.
      03-30-2008, 10:35 AM   #15
ersin
ersin's Avatar
124
Thanks for clearing that up, mkoesel.
2017 F80 YMB.
      03-31-2008, 04:52 PM   #16
Davinhci
Davinhci's Avatar
55
Drives: 08 M3 E92 & 08 E70 X5 4.8
2008 M3  [0.00]
yep no run flats, just repair kit like on the E46
      03-31-2008, 05:31 PM   #17
my2008m3
my2008m3's Avatar
Drives: 2008 M3
lebreeze
Yes Lebreeze, the CANADIAN M3 does indeed come with Michelin Pilot Sport run flats. The 2008 Canadian M3 has FTM (flat tire monitor), which is described in the manual as a system which detects pressure loss by comparing the rotation speeds of the four tires while the car is moving. The flat tire will change it's rolling circumference, thus resulting in a different rpm than the other three.
      03-31-2008, 08:34 PM   #18
lebreeze
162
2008 e92 m3  [0.00]
now i am confused. Why would only canadian m3 come with runflats????????????
      03-31-2008, 09:17 PM   #19
GregW / Oregon
Commander-In-Chief
2067
I can only assume he's being sarcastic? Michelin Pilot Sports or PS2s do not come in a runflat version, and if they did, it would mean very different suspension settings.
Greg Lake Oswego, Oregon, USA
2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450
      03-31-2008, 09:29 PM   #20
turb934
turb934's Avatar
23
Drives: E92 M3
Canadian M3's do not have run flat tires. Tires are Pilot Sport PS2, not Pilot Sport.
      04-01-2008, 02:09 AM   #21
E46 Dave
Drives: E92 M3
No more runflats on M models just tire sealent kit in a can.
      04-01-2008, 10:02 AM   #22
rawedge2
rawedge2's Avatar
60
Drives: 05 STI - 08 M3
and if sealant cant take care of it??? will bmw bring a spare... cuz i would not want the car towed..?? how does that all work?
Search this Thread:
Advanced Search
m3post
