Angel Eyes won't work with Xenons - Pre-LCI 2006 e92
09-01-2016, 10:58 AM | #1 |
51
Rep 219
so story goes...ordered a pair of cheapy AEs from ebay. Installed them and had no errors - apart from the poor brightness, was error free and had a great run for 3 months. Driver side stopped working so I ordered a more expensive pair, supposedly mtecs. Did the same install on my pre-lci 2006 e92 but they refuse to work along with my xenon headlights.
they would work fine as standalone DRLs when i have my headlamp set to '0' but the moment i turn the dial to auto or headlights on, CCC starts throwing left and right DRL errors and after 1 minute both AEs will switch off leaving the xenons on. When I reboot car with just '0' again the AEs will work fine on its own. Seller tells me that pre-lci 2006 needs a different driver to run these AEs, but can't confirm when they are able to ship them in. At this point, I feel like I can code out the errors and reduce the brightness on the LEDs to get them working with my car, the AEs on default, were a little too bright for my liking anyway. I've recently invested in an INPA D-CAN cable and have most of the files setup to run BMW tools and NCSExpert, can someone point me in the right direction to fix this problem? Thanks in advance! |
09-01-2016, 11:28 AM | #2 |
404
Rep 808
See this doc to get you started, in there it explains the settings you need to change to clear aftermarket AE codes...
https://docs.google.com/spreadsheets...CPqY7sEC#gid=0 |
09-11-2016, 10:26 AM | #3 |
51
Rep 219
hey guys any ideas? so i've turned off all cold/warm bulb checks with NCSExpert. Verified since LED license plate and side markers no longer blink on engine start.
my gut is saying that the the AEs require a lot less voltage to run, and with the xenons on, the AEs draw even less power, possibly emulating a short of some kind. INPA shows error codes 9CBB and 9CBC. |
