08-31-2016, 01:58 PM | #1 |
341
Rep 1,184
More Power
Hey guys I have a decent feel of what is out there for mods, but id like to know what you guys think the best route to go is.
Currently 2016 M235i N55 with sport dp, cp, MPE, Intake, JB4 map5 with e85 mixture my thoughts on potential options; 1. add meth... would this even help though as I will likely be close to the fueling limits with the e85 mixture...should help with timing for more power??? 2. Pure stage 2... on e85 mixture seems like it would be a good bump in power, but people say to take full advantage you need to upgrade fueling 3.Pure stage 2 with additional fueling... can anyone chime in on the functions of upgrading the lpfp vs port injection...also from what I understand there is no hpfp availible for the n55 yet 4. Enzo stage 3 turbo (in development)... I am not really interested in this...atleast not yet... I want into the 400-450-500 hp range first is it possible to run the pure stage 2 on pump/e85 mix without additional tuning? Could you go that route then upgrade fueling at a later point? |
08-31-2016, 02:41 PM | #2 | |
743
Rep 893
To answer your last question, yes you could do the upgrades in stages and add the port injection down the road. Tuning wise you'll be fine with just the jb4 but at these power levels I would recommend a back end flash.
2019 SG M5C
2015 SO M3 6MT 2015 BSM M235xi |
08-31-2016, 03:56 PM | #3 |
5554
Rep 5,372
A different, faster out of the box car would be a far cheaper and less problematic solution. It will be cheaper then blowing up that $16K motor (not installed) or that $8K automatic (not installed) or that $5K 6MT (not installed). These cars can handle some serious power, but there is a risk. It would be cheaper to go out and buy C6 Z06 and call it a day. Just being honest.
08-31-2016, 04:36 PM | #4 | |
341
Rep 1,184
I believe the pure stage two runs about $2500 plus install which is not an insane amount. |
08-31-2016, 05:20 PM | #5 | |
715
Rep 1,541
08-31-2016, 05:31 PM | #6 |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
Garage List 2013 BMW 335i [10.00]
2015 BMW 228i M Spo ... [0.00] 2013 Ford Focus (DD) [0.00] 2001 Alfa Romeo 156 [0.00] |
You can do a pure stage 2 turbo and keep the stock fuel system it would give you like 450/450 on 93. Darkiedm4 has done this and it's worked for him very well before.
Doing a stage 2 really opens doors for future mods if you get power hungry. I did a stage1 turbo but I didn't want to spend $3000k or upwards on the 2.
FBO-PS1 and stuff
08-31-2016, 05:41 PM | #7 | |
715
Rep 1,541
I'll run 100oct with a small ethanol mix, instead of PI and LPFP upgrade, when I want to run more boost. I assume that will get me close to a PI/LPFP setup. Anyone run the PS2 like this?
FSociety3812.50 |
08-31-2016, 05:46 PM | #8 | ||
Dejan
1753
Rep 4,197
I would try running a few gallons of e85 at this point see how your car likes it. It's a strange thing but some cars like it some don't, some more some less e85. Last year I ran 4-5 gal of e85 no issues. This year on my second mix my car HPFP flipped out. Started sounding like a type writer. At least this way you'll somewhat know your limitations moving forward to a ps2.
FBO-PS1 and stuff
Anthony235715.00 |
08-31-2016, 06:12 PM | #9 |
743
Rep 893
On stock fueling you'll be limited to 16-17psi to redline. If you want more boost you'll need meth or pi. I recommend pi since the meth is limited to around 23psi. With pi you can push over 27psi boost although you'll likely blow your turbo at that point.
Short answer is that you need port injection to truly max out this turbo.
2019 SG M5C
Jadar1752.50 |
08-31-2016, 07:26 PM | #10 | |
341
Rep 1,184
08-31-2016, 10:18 PM | #11 |
Car Enthusiast
282
Rep 501
Random Question
Can you run a PI kit when using still pump fuel or is that pointless. I do not have access to E85 and plan on doing a Stage 2 turbo and goodies over the winter months. I also read someone recommending having a back of Flash on the DME. Is this the best/only way to make the serious power for this turbo? So do you just Flash the DME and the JB4 acts as a Boost controller for the car? (If any of these questions are super noob or have been answered a million times dont be afraid to tell me to use the search engine lol) |
08-31-2016, 11:25 PM | #12 | ||
677
Rep 1,349
Drives: BMW F80 M3
08-31-2016, 11:30 PM | #13 | |
677
Rep 1,349
Drives: BMW F80 M3
You can run a backend flash and use jb4 as boost controller. |
09-01-2016, 05:02 AM | #15 | |
Dejan
1753
Rep 4,197
FBO-PS1 and stuff
PeterPure677.00 |
09-01-2016, 06:56 AM | #16 | |
50
Rep 70
09-01-2016, 07:43 AM | #17 |
IG @bmwF9xG80
3813
Rep 7,593
Drives: G80 M3, X4M, G07 X7m50
dd1981 crazy especially being PWG you're more e85 friendly than EWG cars ... was that before or after =D (im sure you can run e85 now haha)
Darkiedm4 Luminous Great advice by everyone +1
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
PeterPure677.00 |
09-01-2016, 08:18 AM | #18 | |
Dejan
1753
Rep 4,197
FBO-PS1 and stuff
09-01-2016, 08:44 AM | #19 |
153
Rep 390
@Op if i were you, i would skip PI for safer option in the future. There are discussions on other forums how unsafe it could be, even tho it doesnt happen a lot but it could. MMP was a victim IIRC.
09-01-2016, 10:02 AM | #20 | |
743
Rep 893
2019 SG M5C
09-01-2016, 12:20 PM | #21 |
341
Rep 1,184
Thanks everyone lots of good info! It sounds like though route to go would be p stage 2 then fueling later if I feel the need.
Time to do some more research on that while I save. Are there any good diy turbo installs on here? I didn't see any on the pure site. |
09-01-2016, 01:20 PM | #22 | |
715
Rep 1,541
