2010 2011 BMW 5 Series Forum F10 F10 530d SE Bi-xenon headlights |
08-29-2016, 06:17 PM | #1 |
Rep 69
I was surprised to discover that of the 4 headlights on my car, only the outer 2 ever illuminate - these provide both dipped and main beam, whilst the inner two seem merely to serve as mounts for the running lights.
Is this normal? If so, it seems a waste! |
08-30-2016, 01:58 AM | #2 |
1399
Rep 8,083
Yes it's normal for non-adaptive lights. If you have adaptive lights then the inner lens is used for the cornering light.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
08-30-2016, 01:46 PM | #3 |
44
Rep 226
Yes, Bi-Xenon means it does both main and dipped with the same bulb, basically the top of the beam is cut off to give you dipped. That's the case with most Xenon headlights. Some cars have an additional halogen main beam unit (my Porsche does) which makes a decent difference.
The Adaptive LEDs use all four headlight units, the top half of all 4 are lit on dipped beam then various other LEDs come on in the lower part of the units (plus side) when you switch to main beam or auto high beam (even better) |
