NFRM to FRM3 help needed.
08-29-2016, 09:28 AM | #1 |
16
Rep 458
Not so much of how to code a new FRM3 to work with the car, this part has been done by the dealer. I need help on what needs to be change on my laptop to start coding the new FRM3.
The part no. of the new FRM is 61-35--9-390-491, which I believe is FRM3. My computer was setup to code my original NFRM, worked fine. After the upgrade to FRM3, I still only see NFRM after choosing E89->CAS, and when I pick NFRM to read ECU, error popped up. I'm guessing there's something I need to change on my laptop, but don't know what. Would the software recognize that there's a new FRM3 and show FRM/FRM3 instead of NFRM in the module list? Please help. Thanks. |
08-29-2016, 03:09 PM | #3 |
16
Rep 458
But y can't I read the NFRM ecu? How do I make sure that the NFRM I see in the list is the new FRM3? does the software automatically recognize the new hardware and knows how to read it?
08-29-2016, 04:52 PM | #4 | |
529
Rep 2,503
Just physically inspect the footwell module and read label...it will take 30 seconds.... If still not sure read UIF with INPA and compare...but better to visually inspect the module and read label on it. |
08-29-2016, 05:21 PM | #5 |
BimECU
193
Rep 759
change prod. date in FA before reading/coding
08-30-2016, 09:08 AM | #7 |
16
Rep 458
I would think that this has been done by the dealer. You are talking about change the prod. date of the FRM3 right? Dealer programmed it before getting the car back, everything works, I just can't code all the features I want to the new FRM3, so was thinking must be software on my computer.
I think it should be pretty old, do I just replace the all the directories if I get new version? |
08-30-2016, 10:47 AM | #8 |
529
Rep 2,503
Production date does not need to be changed for FRM3.
Only FRM2. And that is only so that NCSExpert can see there is NFRM and not FRM. With FRM3 this is done automatically. Anyway, dealer would just have ISTA and run a retrofit program. It definitely sounds like you need latest Daten files of dealer updated your I level. |
08-30-2016, 11:03 AM | #9 | |
16
Rep 458
08-31-2016, 03:07 AM | #10 | |
Rep 69
I updated to V55 datens and that still had the same issue. Only when I updated to V59 thanks to wildcatcrazy's request file on here did I finally gain access to the FRM3.
Le Mans Blue/Lemon 10' 135i DCT - N55 - PPK Stage 1, 18" Style 269's w Michelin PS4's
08-31-2016, 08:51 AM | #11 | |
16
Rep 458
Downloading ... |
