2Addicts
2Addicts
2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum High Speed Setup (Option 840)
      08-24-2016, 12:24 PM   #1
amw896
amw896's Avatar
583
Drives: 2015 BMW M235i
2015 BMW M235i  [10.00]
Hey All,
Has anybody seen or is familiar with Option 840 - High Speed Setup on the build sheet? Does this mean I have a higher top speed than 155mph?
I know it came up in another thread that the stock tires are a good indicator. Mine came with the Y speed rating 19"s.
      08-24-2016, 01:57 PM   #2
wjjkoevoets
Bright Sky
wjjkoevoets's Avatar
Netherlands
1164
Drives: BMW M235i (8AT)
2014 BMW M235i  [0.00]
Originally Posted by amw896 View Post
Hey All,
AFAIK if you have the all-season run flats the top speed gets limited to somewhere around 130 mph. If you get summer tires the car gets limited at 155 mph which should be the high speed option.
BMW ///M235i (EBII) - BM3 (+TCU) - Wagner DP - ER CP - ER TIC CP - CSF FMIC - GFB DV+ - Pure Inlet - K&N Drop-in AF - MPE
Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive.
amw896582.50
      08-24-2016, 06:32 PM   #3
raleedy
160
Drives: 2016 228i 6-speed
Y speed rating is 300 kph. But the BMW higher speed limiter is set for 155 mph.
Appreciate 2
amw896582.50
bryan_G011164.50
      08-25-2016, 10:43 AM   #4
Zooks527
310
Drives: 2015 M235xi / 2005 Tacoma 4x4
No. It means that you have the 155mph top speed limit, and not 130mph. All-season tires come with the lower speed limiter.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/BimmerTech amp, Enhanced BT
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi
2addicts
