2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Evolution Racewerks F3X / F2X Oil Cooler Being Released!!!
      08-23-2016, 09:28 PM   #1
Mike@N54Tuning.com
Joint Chiefs of Staff
4918
Drives: 2007 335i, 2015 M3
Evolution Racewerks F30 Oil Cooler will be releasing soon!
The details I got so far from ER are as follows...
The oil cooler features are as follows:
· Large 9"x8"x2" (11"x8"x2" with end tanks) Oil Coolers
· Over 350% larger capacity than the factory oil cooler
· Optional Aluminum Shrouding to direct airflow through the oil coolers for improved efficiency
· Made in USA.
· Limited Lifetime Warranty of all manufacturers’ defects.
Will come in anodized black or standard finish and there will be an optional shroud kit available.
Pictures and more info coming shortly!! F30 fitment is confirmed and F20 being tested this week!
Mike
      08-23-2016, 10:32 PM   #2
abirmaher
abirmaher's Avatar
841
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
  [0.00]
2018 BMW M2  [10.00]
Subbed
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010
The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35
      08-24-2016, 01:25 AM   #3
ABPReader
Deserter
ABPReader's Avatar
No_Country
215
Drives: BM&W
· Made in USA.
Mike
Nice ! Do you know if it will fit on the european M235i ? Our cars have different cooling system from factory (this is why we don't have the same front bumper).
      08-24-2016, 09:42 AM   #4
Anthony235
Anthony235's Avatar
715
Drives: m235i
2015 BMW  [0.00]
· Made in USA.
Mike
Will it use the factory oil cooler lines/connections (or AN fittings and line) and factory oil cooler thermostat? I ran a setrab on my last car.
Side question: For cars that come with the factory secondary cooler on the driver side. Is that a tranny cooler or for water (radiator)?
      08-24-2016, 10:19 AM   #5
mdputnam
mdputnam's Avatar
289
Drives: 135i & M235i Convertibles
It's a water cooler...
      08-24-2016, 10:24 AM   #6
Anthony235
Anthony235's Avatar
715
Drives: m235i
2015 BMW  [0.00]
Great, I hope someone releases an upgraded secondary water cooler as well.
      08-24-2016, 11:51 AM   #7
Dylan86
Dylan86's Avatar
1330
Drives: F15d msport, F22 m235i
Has anyone run into issues with heat on a 235?
      08-24-2016, 12:13 PM   #8
XutvJet
5554
Drives: 2011 Cayman Base, 2016 M235
I was wondering the same thing.
Over-specing an oil cooler is just as dangerous as under-specing one. Too large a cooler and the oil will never get up to operating temp on the street. That's bad news bears.
      08-24-2016, 12:31 PM   #9
Mike@N54Tuning.com
4918
Would need a test car for fitting
Mike
      08-24-2016, 12:32 PM   #10
Mike@N54Tuning.com
4918
Should have its own lines.. I'll have more details shortly..
Mike
      08-24-2016, 01:10 PM   #11
Anthony235
Anthony235's Avatar
715
Drives: m235i
2015 BMW  [0.00]
For the street it really won't be necessary, unless you do aggressive canyon runs in high temps.
As for it under cooling...It should not be an issue if it utilizes the factory oil thermostat. On my NISMO Z I had to run a completely aftermarket oil cooler solution that added a thermostatic plate. This allows the car to get up to a good operating temp before it starts flowing to the oil cooler.
So as long as ER one uses some sort of thermostat it should not be an issue. Though even with that it will take longer than normal to get up to operating temp.
      08-24-2016, 01:13 PM   #12
Anthony235
Anthony235's Avatar
715
Drives: m235i
2015 BMW  [0.00]
Mike
I would be interested in a an option that allows us to utilize the factory lines. AN fittings can be tricky when it comes to getting them just right (leaks). Would be nice if they include conical washers to mitigate the potential risk if they do use AN fittings.
Can you tell I've ran oil coolers before? lol
What core are they using? In house or aftermarket?
      08-24-2016, 08:00 PM   #13
Evolution Racewerks
Evolution Racewerks's Avatar
140
Drives: 20 M340i,15 M4,12 328i,08 135i
The F30 oil cooler will replace the factory oil cooler lines with AN fittings and lines. It will retain the factory oil thermostat. It also retains the factory oil heatsink cooler.
The secondary cooler (driver's side) is an auxiliary coolant (water) cooler.
      08-24-2016, 08:13 PM   #14
Evolution Racewerks
140
Anthony is correct. That is the purpose of the oil thermostat, to not allow oil temperatures to drop below a certain temperature.
The N54 and N55 engines run very hot oil temps. This still holds true for the N55 in the F30. This is even more evident on the track. This we tested during our development of the oil cooler. With the factory oil cooler, temperatures would reach 260F or more. With our upgraded oil cooler, temperatures drop to around 235-240F which is the normal operating temperature. Temperature stayed very consistent throughout the session unlike the factory oil cooler which would have big spikes in temperature.
Appreciate 2
Taunto281.50
      08-25-2016, 10:38 AM   #15
Mike@N54Tuning.com
4918
Thanks for posting the additional info!!
Mike
      08-25-2016, 11:42 AM   #16
Anthony235
Anthony235's Avatar
715
Drives: m235i
2015 BMW  [0.00]
Good to hear. For me 260* and I start to get worried. 280* and it's time to go for a cool down lap ASAP.
From the factory it seems the oil thermostat opens at 240*. What will the ER open at? Will the kit come with a new oil cooler valve? I think the BMS one makes it open all the time. I've seen someone else offer one that opens at 180* and think that is the best option.
Please also include conical AN washers with the kit
https://www.pegasusautoracing.com/pr...p?Product=3202
Any plans on doing anything with the secondary radiator?
      08-26-2016, 12:48 PM   #17
Mike@N54Tuning.com
4918
The kit retains the factory oil thermostat..
Mike
      08-26-2016, 02:23 PM   #18
XutvJet
5554
I could have sworn the M235 runs a more robust oil cooling system than the one used in the F30 N55. We all know the N54 is an oil killer.
2addicts
