INPA - code for o2 sensor and fuel trim reads
08-18-2016, 10:53 AM | #1 |
Rep 26
I need to be able to read and view my O2 sensor data and fuel trims. Do you know if INPA can do that too? If so how and where do I get those codes? Thanks
08-18-2016, 03:15 PM | #2 | |
Ballin' out of control.
520
Rep 1,289
EDIT: Or the MSD80 system test lambda probe screen...E90 -> MSD 80.0 -> <F9> system diagnosis -> <F3> EOL - misassembled L-probe:
Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms
Last edited by 808AWD325xi; 08-18-2016 at 03:34 PM.. Reason: added MSD80 system test lambda probe screenshot |
08-18-2016, 07:24 PM | #3 |
Rep 26
Is this live data? It doesnt look right to me. Looking for the oxygen sensor data, fuel trims , MAP TPS live performance data.
Or maybe I just don't understand what you posted. can you explain what each is? Last edited by kofiboadi; 08-18-2016 at 07:31 PM.. |
08-18-2016, 10:57 PM | #4 |
520
Rep 1,289
Yes, it's live lambda control fuel adaptation and fuel trim data.
08-19-2016, 11:06 AM | #5 |
Rep 26
perhaps the names are confusing me. which of above corresponds with (Is the)
Short Term Fuel trim bank 1, long Term fuel trim Bank1 Short Term Fuel trim bank 2, long Term fuel trim Bank2. And Oxygen sensor Bank1 sensor1 Oxygen sensor Bank1 sensor2 Oxygen sensor Bank2 sensor1 Oxygen sensor Bank2 sensor2 |
08-19-2016, 04:43 PM | #6 | |
520
Rep 1,289
http://www.bmwfan.lt/forumas/downloa...57a1c6d2ad92fd http://www.europeantransmissions.com...ptationBMW.pdf
08-19-2016, 08:11 PM | #8 |
Rep 26
I need a little help understanding these fuel trim and o2 sensor data I just pulled from my reader.
o2sb1s1: 1.95V (barely changing) o2sb1s2: 0.08 -0.8V (fluctuating) o2sb2s1: 2.0V (barely fluctuating ) o2sb2s2: 0.36 ( stayed the same throughout; is not fluctuating at all) Multiplicative Mixture Adaptation (STFT) Bank 1: -651 to 618% (fluctuating very very fast between range) Additional Mixture Adaption (LTFT) Bank 1 : 0.36% Multiplicative Mixture Adaptation (STFT) Bank 2: -581 to 651% (fluctuating very very fast between range) Additional Mixture Adaption (LTFT) Bank 2 : -533 to 510% (fluctuating very very fast between range (-533 and +510)) Can you help me understand this? What is possibly the issue? Thanks I also have error code and misfires on all my injectors, these are brand new injectors by the way. replacing injectors didn't fix issue I have attached the graphs too. Thanks |
05-20-2021, 09:49 PM | #9 |
Rep 31
Help.
what's up guys, here trying to diagnose if my oxygen sensors are bad or going bad. Last year ( 2020 ) I install new oxygen sensors 4 in total, after driving it for 4 months the SES light appear on my dash i did scan, but there are no codes showing up, but the symptoms are the same when i had them bad, poor acceleration etc.....and I also notice my spark plugs on cylinders 4-5-6 are dark wile cylinders 1-2-3 are clean. I check if there was any oil leak and there was non. Here is a screenshot of INPA wile I was driving from work -home When I have the accelerator pedal press, BANK 1 at is 2.06 and BANK 2 is at 1.98 . But ass soonest I release the pedal BANBK 1 is at 3.13 AND BANK 2 at 3.17 . ¿ Is this normal ? This is other screenshot is when i had my car in park and idling |
