08-12-2016, 05:29 PM | #1 |
37
Rep 100
Heated side mirror problem
A couple of days ago I noticed that my side mirrors were no longer removing condensation after driving a few miles in the morning. Last night I started the car, turned on the rear defroster for comparison, and waited 10 minutes then checked the rear window and the side mirrors with an infrared thermometer. Rear window read at 100F and the side mirrors were at air temperature, i.e., not heating. I'd check the fuse but I don't know which one it is and I cant find anywhere a fuse diagram for the F22. Can anyone help? Do you know which fuse it I should be looking at for the heated mirrors, or at least where I can find a fuse diagram?
08-13-2016, 04:25 PM | #3 |
67
Rep 201
Drives: 2017 GT350
I don't have heated mirrors, but if I did I'd bring it in for warranty
08-13-2016, 04:30 PM | #4 |
516
Rep 1,452
08-13-2016, 04:41 PM | #5 |
37
Rep 100
Yeah, I will take it in for warranty if I replace a fuse, and that blows again. And actually, the owner's manual doesn't tell you everything you need to know because there's no fuse diagram in the there. Really, like I wouldn't look there. For what it's worth, I believe there's supposed to be a fuse diagram in the front fuse compartment, in a flap underneath, but unfortunately mine is empty. In any case, thanks anyway. later fellas.
08-13-2016, 04:48 PM | #6 |
516
Rep 1,452
It tells you where to look. In theory that is all you need to know. There must be a reason they chose not to print one in the manual. Probably too many option packages. Sorry that yours appears to be missing.
08-13-2016, 05:54 PM | #7 |
15
Rep 72
The fuse panel you seek is in the cargo area (trunk), under the deck lid in the back right corner. There should be a printed panel of fuse types and locations.
Hope that helps. Bozman |
08-14-2016, 02:15 PM | #8 |
71
Rep 222
Rear defroster in the '11 328i is one of the first things to get sacrificed when the battery is low. Have you drained your battery at all lately? Maybe the side mirrors in the 2er take this spot in priority order.
08-15-2016, 04:02 PM | #9 |
27
Rep 62
Fuses
This from my 2016 M235i (RHD in UK but I doubt that makes a difference):
The sheet of fuse allocations is clipped to the back (nearest the cabin) of the fuse box in the boot (trunk). See the photos that suggest you want fuse #22 in the box under the bonnet (hood). Best of luck |
08-16-2016, 09:39 AM | #10 | |
37
Rep 100
08-16-2016, 10:49 PM | #11 | |
39
Rep 106
08-17-2016, 09:51 AM | #12 | |
37
Rep 100
If the mirrors won't move, then I'll replace #22, otherwise I'll be making an appointment for service. |
08-19-2016, 12:02 PM | #14 | |
27
Rep 62
Someone else made the point that the single fuse appears to serve all of the mirror functions so just trying to adjust them is a useful test. I presume that you're sure you have mirror heaters? In UK, the heat/dim/fold functions come together as an option. |
05-30-2017, 12:31 PM | #15 |
142
Rep 671
What was the outcome? This morning, I had a lot of condensation on my drivers side mirror and no matter what button I pressed it was like the mirror never got hot to remove the condensation..
Could it be that my car's not equipped with heated side mirrors? I looked up what was included in the Premium package and cold weather package and neither showed heated side mirrors..... Unless the option is standard.. I guess I better look at the build sheet.
'20 240ix convertible
05-30-2017, 12:54 PM | #16 |
142
Rep 671
Update... There's got to be more to this... I just found in the owners manual that both exterior mirrors are automatically heated when the engine is running... WTH? If they were automatically on, how come it didn't remove the condensation?
I guess I need to take it in to see what the problem might be.. Because it seems these always heated mirrors aren't heated.
05-30-2017, 10:51 PM | #18 | |
142
Rep 671
So either my automatic heated side mirrors are broken or there's some other catch to that I'm not aware of... I'm gonna have to find my temp gun to see how hot, if at all it gets.
05-31-2017, 08:39 AM | #20 | |
142
Rep 671
What kind of non-sense is that? Are you saying I have to wait for a cold night to test this? All the manual said was that it was on automatically. There are many mornings in the 60's.. even in the 70's where I have condensation on my car. Thanks for the head up on this...
05-31-2017, 09:43 AM | #21 |
37
Rep 100
An update: I did indeed take the car to the dealer last year when I first wrote about the issue. Their answer: exterior mirror heating only activates at temperatures of 37F and lower. I think this is silly, but indeed it is true. This past winter the mirror heating worked fine. My old BMW had the mirror heating working constantly, which was--as mentioned--very effective at removing morning dew during the spring and summer.
crabu2141.50 |
05-31-2017, 09:56 AM | #22 | |
142
Rep 671
Dang it!! 37F is way to low of a temp... I wonder if it can be coded to work at higher outside temps.
