2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Rear Differential Initial Fluid change
      08-09-2016, 07:53 AM   #1
SchmullisBob
40
Drives: M235i Coupe - 2015
For those that know:
2015 M235i Coupe.
Manufactured 06/2015.
Purchased new 03/2016 (was the dealer's demo)
Current Mileage 5,300
Open Rear Differential
Question: Should I change the differential fluid now, considering it the initial change or just wait till I reach 30,000 miles?
Thanks!
      08-09-2016, 01:27 PM   #2
raleedy
160
Drives: 2016 228i 6-speed
If the differential is open, what's keeping any fluid in there?
      08-09-2016, 03:47 PM   #3
Rayscott
376
Drives: BMW 228ix
Gravity??
      08-09-2016, 05:19 PM   #4
vintage42
Drives: 1997 BMW Z3 1.9
Drain plug.
Open differential applies the same amount of torque to each wheel.
Limited slip differential allows more torque to be transferred to the non-slipping wheel.
      08-09-2016, 07:38 PM   #5
Kolyan2k
916
Drives: 2006 S2000
Originally Posted by vintage42 View Post
Drain plug.
That wasn't OPs question lol
      08-09-2016, 07:58 PM   #6
vintage42
It seemed raleedy in #2 misunderstood open differential.
      08-09-2016, 08:09 PM   #7
overcoil
3069
Drives: M235i 6spd
I'm at two years and 17k miles and plan on doing rear diff within next few months.
But a 30k, 60k, 90k is the longer drain intervals I'm o.k. with.
      08-10-2016, 04:06 AM   #8
Zooks527
310
Drives: 2015 M235xi / 2005 Tacoma 4x4
I think it's more likely you misunderstood he was making a joke.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/BimmerTech amp, Enhanced BT
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi
      08-10-2016, 09:06 AM   #9
Tpeterson
Tpeterson's Avatar
157
Drives: 228i MSport/THP/MT/
2015 M235i Coupe.
Thanks!
I considered doing a break in change at about 1200 miles, but decided it was overkill.I'm going with 30,60,90 intervals. Since most owners never change this fluid and BMW considers the factory fill lifetime,I think my intervals are excellent preventive maintenance.
      08-10-2016, 09:53 AM   #10
Kolyan2k
916
Drives: 2006 S2000
I wonder if those who replace diff fluid also do tranny at the same time?
      08-10-2016, 11:14 AM   #11
Zooks527
310
More typically, transmission fluid at 50k (ZF's recommendation IIRC), up to 100k (BMW's recommendation). After that, you find yourself in the midst of the "Change it! / No, never after 100k if the first time!" debate.
      08-10-2016, 12:11 PM   #12
Kolyan2k
916
Drives: 2006 S2000
I've got 60k on my Lexus and neither tranny or diff have been serviced. Both filled what they claim a lifetime fluids and tranny is not even serviceable, drain plug only drains 30% of fluid. Debating doing at least that 30% and maybe diff at next service.....will cost about $400 bucks and not even sure if its worth it
      08-10-2016, 03:33 PM   #13
SchmullisBob
40
Check out the BavAuto suggested maintenance intervals:
https://www.bavauto.com/Assets/inst_pages/e90mc.pdf
Tpeterson156.50
      08-11-2016, 04:29 PM   #14
Tpeterson
Tpeterson's Avatar
157
I printed a copy of this maintenance schedule for myself several years ago. It is basically the BMW recommended maintenance before they started providing "free' maintenance.Mike Miller's Old School Maintenance Schedule is also about like BavAuto's.No such thing as lifetime fluids unless you want a short lifetime for the components of your car!
Search this Thread:
Advanced Search
2addicts
