03-26-2008, 08:12 AM | #1 |
1635
Rep 2,773
Drives: F95 X5MC
BMW Advanced Battery Charging System
Does anyone use the BMW Advanced Battery Charging System (part # 82 11 0 026 663)? I used this charger (with cigarette lighter adapter) on my E46 M3 and never had a problem with the power connection. However, on my E92 M3, when I plug it into the cigarette lighter, sometimes it works, and sometimes it doesn't. It seems that when I turn the car off by pressing in the clutch and hitting the Start/Stop button, the car shuts down as well as the power to the cigarette lighter. However, if I turn the car off using only the Start/Stop button and hit it two or three times, the power to the cigarette lighter stays on. Has anyone else had this experience?
Here is the info about the BMW Advanced Battery Charging System # 82 11 0 026 663: If you park your car for any extended period of time you need this little unit to keep the battery charged. Plug it in and you're all set! 1.25 Amp battery charger designed to fully charge and maintain a battery at a proper storage voltage without the damaging effects caused by trickle chargers. The new BTP micro-chip technology applies the correct peak charge, then automatically maintains the battery at the perfect float voltage which virtually eliminates battery destroying sulfation! Temperature compensation ensures optimal charge voltage even in extreme weather conditions. Powder coated aluminum chassis. Spark Proof! Reverse polarity protection ensures safety. Built in 72 hour timer will protect a marginal battery from over charging.
2020 F95 X5///M Competition CarBahn Autoworks Stage 1 | 2023 Lamborghini Huracan Tecnica
03-26-2008, 09:40 AM | #2 | |
2258
Rep 12,985
In your case I would assume that it is the same issue. Last edited by Technic; 03-26-2008 at 10:21 AM.. Reason: syntax |
03-26-2008, 09:44 AM | #3 |
1635
Rep 2,773
Drives: F95 X5MC
You could be right. The parts guy at my dealership said the clutch has some kind of switch on it that disables power to the vehicle, including the cigarette lighter. I'm guessing that if I shut the car down using only the Start/Stop button, power to the lighter will remain.
03-27-2008, 04:55 PM | #4 |
Rep 95
Looks like a Battery Tender Plus with BMW's name on it... Just get the following and use the included quick-disconnect cable to hardwire it to your battery - lighter problem solved!
MFR link: http://batterytender.com/product_inf...a9659e15f81bcc Amazon link (good price, free ship): http://www.amazon.com/Deltran-SuperS...6654708&sr=8-1 I use this on my Z06 and have had no issues...
2006 Corvette Z06
Black / Ebony - 459RWHP / 438RWTQ 2005 Subaru Legacy 2.5 GT Wagon Brilliant Silver / Tweed M5 - 229AWHP / 260AWTQ |
03-27-2008, 07:14 PM | #5 |
1635
Rep 2,773
Drives: F95 X5MC
Right, I think it is a Battery Tender rebranded for BMW. Thanks for the links, but I'd like to keep the charger I have. The power to the cig lighter definitely has something to do with the clutch and Start/Stop button. If I turn the car off using the Start/Stop button, and not the clutch, power to the cig lighter stays on.
12-21-2009, 08:02 PM | #6 |
Doug
Rep 15
BMW OEM Battery Tender on E92 with comfort access - anyone have luck with the plug-in
Need to bring this up again. So both my local BMW and parts and service gurus say the BMW Advanced Battery Charging System (part # 82 11 0 026 663) will definitely work with the plug-in adapter to the cigarette lighter on my 09 E92. Well after trying it tonight, nothing but the damn blinking red light. I don't find power to the lighter, wiggling the adapter NG. Is the jury out on this, or can you really only use the ones with the alligator clips to the battery or the other hookups I've seen on this site. If the one with the plug to the lighter is NG, why the hell do the fools at BMW sell this type? The pushing of the start/stop button etc. does not work for me. Anyone have success with this plug-in charger on this model BMW or is this E92 really designed to be cold to the lighter with the power off?
12-21-2009, 08:05 PM | #7 | |
BimmerPost Supporting Vendor
8056
Rep 18,786
Drives: BMW
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
12-21-2009, 08:10 PM | #8 |
Doug
Rep 15
Battery Tender
What a pain in the ass. Why would I want to leave the trunk lid open or the hood or jury rig the damn thing? Another BMW electronic screwup.
12-22-2009, 12:05 AM | #9 |
151
Rep 1,599
I Bought an Adaptor
I bought a socket to aligator clips adaptor cable a few years ago so that I could use the BMW charger that I bought for my E46 on other cars that I had. I think I got it at Radio Shack, but I may have found it online. It works fine. I've been using it to connect to the jumper connection points under the hood. The charger works as expected this way.
12-22-2009, 12:56 AM | #10 | |
2258
Rep 12,985
My solution was to install a direct 12V OEM socket in the trunk: |
12-22-2009, 06:28 AM | #11 |
One mod leads to another ...
415
Rep 2,900
Just drive the damn things and then you don't have to worry about it.
Current: 2014 F10 M5 Previous: 2015 F80 M3, 2013 E92 M3, 2013 F10 M5, 2009 E90 M3, 1998 E36 M3 |
12-22-2009, 08:34 AM | #12 |
684
Rep 5,069
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
Garage List 2009 Porsche 911 997.2 [10.00]
2019 Hyundai N (Sold) [10.00] 2013 BMW M3 (Sold) [10.00] 2011 1M Coupe (Sold) [8.78] 2008 E90 M3 (Sold) [8.60] 2007 Z4 Mcpe (Sold) [9.50] 2005 BMW M3 (Sold) [10.00] |
Best solution yet! To those using the terminals in the engine bay, I read that that is not recomended and you should use the terminals on the battery itself.
12-22-2009, 09:16 AM | #13 | |
Master Chief
19
Rep 641
that connection in the engine bay is good enough to jumpstart the car so why cant it take a battery tender? |
12-22-2009, 01:51 PM | #14 | |
1635
Rep 2,773
Drives: F95 X5MC
Are you sure? The M3 Owner's Manual states on page 214 (Charging the battery) "Only charge the battery in the vehicle via the terminals in the engine compartment with the engine off. Connections, refer to Jump starting on page 217."
12-22-2009, 02:44 PM | #15 | |
256
Rep 5,012
Same thing buddy. Am debating if I should hardwire a BT pigtail to this car. I'd have to add extra cable as it's a long stretch, and cable would be fugly coming from the terminals under the hood. I usually attach the pigtail with the cap's 'tail' around one of the hood grile slats, and it's nearly invisible. But all my other cars have the battery in front, and installation is practically invisible with the hood open. For now will keep opening the hood every time. Good thing is I don't use the car much. Take care. |
12-22-2009, 09:54 PM | #16 | |
124
Rep 4,145
Thanks and Merry Christmas.
2017 F80 YMB.
12-22-2009, 10:44 PM | #17 | ||||
684
Rep 5,069
http://www.m3post.com/forums/showpos...86&postcount=8 Quote:
12-22-2009, 11:29 PM | #18 | |
8056
Rep 18,786
Drives: BMW
The interior cigarette lighter is a different story, going the route Technic did with the auxiliary 12V socket is not a bad idea.
12-22-2009, 11:36 PM | #19 |
256
Rep 5,012
12-23-2009, 12:18 AM | #20 |
20
Rep 390
Isn't this "BMW Advanced Charging System" just a relabeled "battery tender plus" brand battery tender.
Sorry for the large resolution pic, i copied the image link from the manufacturer. I would bet that BMW would charge more than what the street price on the battery tender plus is going for? |
12-23-2009, 12:56 AM | #21 | ||
405
Rep 6,107
12-23-2009, 12:59 AM | #22 |
405
Rep 6,107
