BMW Coding Tool and Datens question
08-02-2016, 04:31 AM | #1 |
Rep 69
Right, couple of questions I need some assistance with.
I am trying to flash BMW PPK onto my 135i using WinKFP but ran into the issue of my daten files being too old and not recognising the MEVD17 DME (V49). So updated the WinKFP daten files using BMW Coding Tool to V55. The WinKFP update went fine and now recognises MEVD17 However... when updating the NCS files through coding tool it gets 99% through then says permission denied... (will upload a screenshot when I get back on the laptop) Anyone run into this issue before? **EDIT** Think i may have found the solution to the above... apparently files need to have read and write permission instead of read only! Also, i have the V59 datens also, is it possible to run WinKFP on V55 datens but run NCS etc. on the V59 using different source files through BMW Coding Tool? The reason I ask is that the ZUSB number I need for PPK flash is on the V55 datens but not on V59 datens. Thanks in advance! KJ Running EDIABAS 7.30 & INPA 5.0.6 through a Virtual Machine. Last edited by KJMotorsport; 08-02-2016 at 04:54 AM.. |
08-02-2016, 06:24 PM | #2 |
BimECU
193
Rep 759
you can find new ZB number as well, there is compatibility file in datens
