07-31-2016, 12:39 PM | #1 |
1418
Rep 2,559
Drives: Rapidly from A to B
Max camber with stock suspension
Anyone know what the maximum negative camber is that can be dialed in without aftermarket camber plates or other modifications? I'm quite happy with the stock suspension but would like a bit extra camber to save my front tires at HPDEs.
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
08-01-2016, 05:33 PM | #2 |
330
Rep 1,084
front camber is not adjustable on these cars at all, so: nada, zero, zip without camber plates or offset bushings
rwalker@rwalker.com (I really dislike Private Messaging)
MetalM29.50 |
08-02-2016, 09:33 PM | #3 |
2049
Rep 3,714
Get camber plates, Vorshlag makes some that work with stock suspension
M3 Adjuster7904.50 |
09-22-2016, 09:49 AM | #9 | |
240
Rep 462
I will see if that is enough for me to forego camber plates. Won't know until I actually get an M2, put on some decent tires and try it on my home track |
09-22-2016, 10:28 AM | #10 |
139
Rep 268
My camber gauge readings are taken from an uneven garage floor so there is some margin for error, but should be close. Outside tire wear is still prominent if you are running hard on the track though Wish they had another degree of adjustability, but that's where camber plates fill the gap. However, on the plus side, the occasional track day at intermediate pace, is probably survivable for most. The hardcore will want more negative camber, or spend more on tires, one of the two
09-22-2016, 10:42 AM | #11 | |
240
Rep 462
If I buy non-adjustable camber plates, I prevent outer shoulder wear on the track but then chew up my inner tread on the street. If I buy adjustable camber plates, I will be fiddling with them constantly and my OCD will get the best of me. If I stay stock, and go all out at the track, I will have to replace my tires constantly. If I stay stock and take it easy on the track, then why bother... oh well, get M2 first, then sort out my remaining 1st world problems later! |
///Mobbin1474.50 |
09-22-2016, 11:45 AM | #12 |
139
Rep 268
Hilarious! So true.
If it is any consolation, coming from a 135i you will be pleasantly surprised! The 135i was a nightmare with stock camber and trying to fit any sort of wider tire up front, thank goodness the M2 is a little more forgiving. |
09-22-2016, 12:12 PM | #13 | |
1418
Rep 2,559
09-22-2016, 12:26 PM | #14 | |
240
Rep 462
Trying to deal with the stock camber on the 135i is a bitch! I ended up getting Dinan camber plates, which ended up chewing up my inner tread when I was not on the track. I have since removed them since I plan on selling my car next year. When you say the M2 is more forgiving, are you saying that its stock camber does not chew up tire shoulders the way the 135i does, or are you saying it accommodates wider tires better than the 135i? |
09-22-2016, 12:30 PM | #15 |
240
Rep 462
With Dinan camber plates and the M3 wishbone/tension rods, I was able to get -2.5 up front on the 135i. Did you find that wider tires alleviated the shoulder wear issue?
09-22-2016, 01:13 PM | #16 | |
1418
Rep 2,559
09-22-2016, 01:54 PM | #17 |
240
Rep 462
The beauty of running a square set-up
09-22-2016, 10:09 PM | #18 | |
139
Rep 268
Speaking of square set up advantages without camber plates, I had great success running my E92 M3 at stock -1.7 camber up front (alignment pins pulled) with 275/35/18's. Rotated religiously and they held up well enough. Drove on the street too. Hopefully we will see this same trend on the M2 with the square set ups. Not looking for ideal, just manageable |
IS+1239.50 |
09-23-2016, 08:17 AM | #20 | |
2080
Rep 2,999
http://www.2addicts.com/forums/showt...t=dinan+camber If yes, what did you like or dislike? I see some complain about top bolt access with some plates brands. Last edited by omasou; 09-23-2016 at 08:45 AM.. |
09-23-2016, 08:42 AM | #21 |
240
Rep 462
09-23-2016, 10:14 AM | #22 | ||
1418
Rep 2,559
No adjustments and no issues. Just gave a 0.7 additional negative camber. I have these on my e36 M3 too. Love them. I called Dinan and they said the 2 series tower design prevents them from making the same for that car.
