2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Need help big issues
      07-29-2016, 01:35 AM   #1
Questofthetune
Questofthetune's Avatar
446
Drives: 13 GT50014 AW M235i(sold)
2014 BMW 235i  [0.00]
So I coded EBT and evreything was great but then I lost my instrument gauge lights and a service message came up. So I loaded the backup and tried to code the ecus back to before and I coded the one that sets off every possible error- I tried to insert a new caf file but no luck.. So uh little help pretty please
      07-29-2016, 05:58 AM   #2
Questofthetune
446
I loaded my saved SVT and coded the entire file and got 7 errors, not sure where to go from here
      07-29-2016, 02:20 PM   #3
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
Probably ask Shawn.
You should not code the whole Ecu tree. You should code just one Ecu at a time
      07-29-2016, 03:29 PM   #4
Questofthetune
446
So I followed revert instructions and my car is back to normal, just took a few restarts. I'll find out later if my Gaige lights are back or not - has anyone ever heard of cluster lights going out with coding?
      07-29-2016, 04:06 PM   #5
Questofthetune
446
I'm also having difficulty getting sport display to work, the rest of the codes have been fine now however
      07-29-2016, 05:15 PM   #6
pikcachu
pikcachu's Avatar
1399
won't work unless you have navigation
      07-29-2016, 06:22 PM   #7
Questofthetune
446
Well that explains it. How about TPMS values? Temp and psi? Nav only as well?
      07-29-2016, 07:48 PM   #8
pikcachu
pikcachu's Avatar
1399
No, that should work as long as you have metal stems on your wheels instead of rubber
      07-29-2016, 07:54 PM   #9
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Certain ECU's will throw errors when coding them. As long as there are no errors shown in E-sys and still have blue CAFD with green check marks when read SVT, then usually fine. Errors on instrument cluster or head unit will either clear themselves with driving or you sometimes have to use external transmitter. You should not be loading SVT. It is fine to load FA if you VO coding without writing changes to VCM.
      07-29-2016, 08:30 PM   #10
Questofthetune
446
Okay that clears it up, now that the cars back to normal and I had success coding EBT and halo brightness I'm feeling bold enough to try and get the rest of the functions up.
Tpms is not working for me no matter what however- I have 3 metal caps one plastic if matters
      07-29-2016, 08:54 PM   #11
pikcachu
pikcachu's Avatar
1399
they need to look like this
you in the US? All M235s in the US will have metal stems
if you have the one below then you don't have the sensors?
      07-29-2016, 10:10 PM   #12
Almaretto
Almaretto's Avatar
2374
Re TPMS: Do you have 2VB in your FA? I switched mine to metal shown. Caps do not matter; but as Pikcachu said, the stems make a difference whether you have metal TPMS or plastic ones that measure by revolutions.
      07-30-2016, 12:27 PM   #13
Questofthetune
446
I am in the US, I just get the green tire color on the screen- no values
      07-30-2016, 03:03 PM   #14
pikcachu
pikcachu's Avatar
1399
That's really weird... I thought all M235s in the US came with the sensors....
And PSI was always displayed... Temp had to be coded in some cases
      07-30-2016, 03:41 PM   #15
Questofthetune
446
Hmm yeah I'm going to a pro coder later today to have him just do the rest of the features and to take a crack at getting some of these (tpms) possibly working
      07-30-2016, 03:46 PM   #16
Questofthetune
446
View post on imgur.com
My stems
      07-30-2016, 04:06 PM   #17
pikcachu
pikcachu's Avatar
1399
those looks like the ones with the sensors
      07-30-2016, 05:14 PM   #18
Questofthetune
446
I guess I'll se whatsup with it, maybe the coder can figure it out- I do really want the tpms data not just OKAY/NOTOKAY
      07-30-2016, 08:30 PM   #19
Almaretto
Almaretto's Avatar
2374
Good luck. On newer head units, PSI should show from factory and it is only the temperature readings that need to be coded. Once the tires turn green after a little driving, it should register shortly after.
      07-30-2016, 08:41 PM   #20
pikcachu
pikcachu's Avatar
1399
Did you buy the car used ?
Maybe the previous guy had different wheels without sensors and coded out the TPMS so it wouldn't throw an error and now if he put the stock wheels back on, the sensors won't do anything if the car was coded out
      07-30-2016, 09:03 PM   #21
Questofthetune
446
It's like your name is Miss Cleo or something haha, yeah exactly what was done, it was used- picked it up a week ago. Off lease just has a few niggles- like changes in volume don't show on any screen? Unless that's normal
2addicts
