2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Cosmetic Maintenance (Wash/Wax/Detailing/Exterior Restoration & Repairs) Smears on Windows
      07-26-2016, 07:10 AM   #1
Cjnj
35
Drives: 2016 228i xdrive
Smears on Windows
I have noticed that since about a month after getting my 2er, that there are "smear" marks on the inside of the glass on the side windows, that smear onto the glass after opening and closing the window. It is on the inside of the glass and rubs off, therefore it is an annoyance at this point (hoping it won't start to damage the tinting and/or glass).
Anyone have any ideas on how to stop it? without taking apart the doors of course.
      07-26-2016, 10:37 AM   #2
tinyTIM
tinyTIM's Avatar
33
Drives: 2016 m235 xdrive
2016 BMW M235xi  [0.00]
The same thing happens on mine. It is an annoyance, especially after a good detail. Interested if anyone here has a solution.
      07-26-2016, 11:36 AM   #3
Beartato
Beartato's Avatar
882
Drives: M235i
I get the same thing, especially when it's been humid outside. I have a microfiber towel I keep inthe glovebox that I use to wipe it off when it happens, I guess that works
      07-26-2016, 11:55 AM   #4
Cjnj
35
At least I;m not the only one (the sales manager hadn't seen it before). I guess that is an idea, just worried it is dirt or something inside the door.
Wonder if putting window cleaner on the window and then operating it to try and clean it off of the seal?
      07-26-2016, 12:08 PM   #5
pz619
3279
Drives: F87 M2C 6MT, Tesla 3
It happens. You'll just need to keep cleaning the window until it doesn't happen anymore. Other solution is basically disassembling the door to clean the rollers directly.
      07-26-2016, 06:01 PM   #6
BentZero
BentZero's Avatar
625
Drives: 6MT Mineral White M235i
Hmm, I don't notice this. Perhaps because I clean my windows every week when I wash my car. I listen to the radio while I'm drying the car so I roll the windows down. When I roll them up they get wet, so I clean them as my last step. I roll my windows down every morning on the way to work and I have no smearing now.
I rev-match from neutral to first
6MT Mineral White on black M235i coupe
Build thread
      07-26-2016, 06:44 PM   #7
BMWZ4
BMWZ4's Avatar
1910
Drives: '23 X1/'23 Allroad Progressiv
I get this all the time. What a PITA. Tried running a cloth with a screwdriver along the inside edge with the window down. Cleans it, but comes back again after a few days.
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
      07-26-2016, 08:02 PM   #8
xantdieselx
Kingslayer
xantdieselx's Avatar
No_Country
411
Drives: 23' M3 Base
Interesting I don't have that problem. Only if it's raining, just rained or I just washed the car will the windows smear.
I always clean the outside glass with 0000 steel wool and Stoners Invisible Glass post wash. Then I make sure not to lower my windows until I'm absolutely the inside of the door (regulator, track, etc) are dry.
I also use a power washer when washing my car so I tend not to get a ton of water getting by the belt molding.
Previous Cars: 2008' 135i, 2010' 328i, 2013' 328i, 2016' M235i, 2017' X1, 2019' M240i
Current Cars: 2019' X3, 2021' M3 Comp
      07-27-2016, 01:29 PM   #9
Grentz
Grentz's Avatar
58
Drives: X5 40i G05
Same problem here from day 1. Quite annoying as it gets a line where the windows roll down a bit from when you open the door.
I have a MF towel in my side pocket that I use to wipe it off every few times.
Current
19' G05 X5 40i
03' e46 M3 Convert.
Past09' e90 335d, 11' E70 X5d, 16' F22 M235xi
      08-02-2016, 08:32 PM   #10
Rayscott
376
Drives: BMW 228ix
I don't have this problem. However, I do get a lot of outgassing from the plasticizers in the dash which put a film on the inside of the windshield. I wipe the window with a dry MF cloth, then use Magic Eraser (twice) followed up with Invisible Glass on a special glass cleaning cloth. The Magic Eraser cuts through the film and removes it.
      08-21-2016, 09:22 PM   #11
SmallTownBoy
Drives: '14 M235i 6MT PSS BSM
I've also had the interior window smearing since day 1.
F22 * (N55 + 6MT) ÷ PSS = FUN
      09-22-2016, 07:38 AM   #12
Cjnj
35
It went away for a while well we had a drought but its back again and now I've noticed 2 small scratches in the tint
      04-25-2017, 06:11 PM   #13
Cjnj
35
Refreshing this post....this is a better idea of what is happening with my my16.
http://www.bimmerfest.com/forums/sho...d.php?t=361396
Anyone figure out a solution for this? And I mean more then keeping a cloth in the car. This seems to be getting worse and doesn't matter weather conditions. I have a scratch on my passenger window from this...it also makes it hard to see sometimes.
Has anyone had the dealer fix the issue under some sort of warranty?
      05-04-2017, 09:41 PM   #14
jmwilson125
341
Drives: 2016 M235i
This was dribinge nuts. I thought I was the only one.
Kinda came up with a solution, but it seems the smears came back. I took a micro fiber towel and hosed it down with window cleaner wrapped it around a trim tool, and gently but forcefully shoved it down into the felt window.seal (window down). smears went away for about a month. I am going to try again.
      05-06-2017, 09:14 AM   #15
Rayscott
376
Drives: BMW 228ix
The smearing is the film created by the outgassing of the plasticizers contained in the vinyl dash. I own a detailing business. Do this: Wipe the glass with a clean microfiber towel then scrub once or twice with a wet Magic Eraser and remove with a MF towel, follow up with a non-ammonia glass cleaner (Invisible Glass) and wipe off with a good MF towel. I use a special MF towel for glass that I get from my detail supplier. You can order it on www.detailedimage.com under the glass section. It will come back but not as often.
      05-08-2017, 08:53 AM   #16
Rayscott
376
Drives: BMW 228ix
Another option is a glass cleaning clay bar. Got one from Griots and it did a good job.
      05-08-2017, 09:14 AM   #17
BentZero
BentZero's Avatar
625
I didn't have this problem for the longest time and now it's back. :/
Build thread
      05-08-2017, 11:37 AM   #18
spencer29
spencer29's Avatar
34
Drives: BMW M235I
I get the same smudging on the inside of the windows. After rolling them down marks appear on the glass.
I believe it has to do with when washing the car soap water slips through the outside seal on the window and when the window goes down and then back up it brings up that dried soap up on the glass.
      05-08-2017, 02:02 PM   #19
Cjnj
35
I don't know but its F*$%ing annoying
2addicts
