European Auto Source (EAS)
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > BMW M4 GTS Discussions
      07-23-2016, 03:26 PM   #1
aboulfad
aboulfad's Avatar
1593
Drives: 2015 M4 MG/SO
2015 BMW M4  [10.00]
M4 & GTS DCT differences
So the hardware is identical (check etk, ASAP, ...), same clutches, mechatronics, housing unit, also identical gear ratio according to this and this.
The F82 GTS tech info Section 4.5:
For power transmission, the F82 M4 GTS uses the M double-clutch transmission M DCT Drivelogic also optionally available for the F82 BMW M4 Coupé without any design modifications. The shift characteristic of the 7-speed M DCT Drivelogic was made even more suitable for motor sports driving and matched specifically to the F82 M4 GTS.
Given the power/torque increase over the M4, what is this "shift characteristic for motor sports, is it mostly the "clutch clamping" thingy?
      07-24-2016, 07:44 PM   #2
OutlawX3M
OutlawX3M's Avatar
298
Drives: 2016 BMW M3 ZCP. 2020 BMW X3M
2016 BMW M3 ZCP  [0.00]
IMO if the hardware is identical then it's software.
Perhaps different shifting programming to account for the increase HP + TQ because the GTS has a different hp + TQ curves. That may change where the optimal power is so they adjusted the shift points in the DCT.
      08-11-2016, 08:05 AM   #3
Bucketsbentley
18
Drives: BMW M4
While the M4 and M4 GTS share the same gearbox, the gearbox was updated as of this month for both M4 and M4 GTS (new parts number). There was a previous update in March. The oil pan and oil windage tray are also new for both models.
      08-11-2016, 08:39 AM   #4
dr.mba
dr.mba's Avatar
275
Drives: 2017 F. Grey M3 ZCP
Interesting... So does this affect F80/M3 as well? I assume it's the same transmission after all.
M
      08-11-2016, 01:01 PM   #5
Bucketsbentley
18
Drives: BMW M4
M
Yes same transmission
      08-11-2016, 03:46 PM   #6
dgp
103
Drives: Bicycle...
Any idea what's new under new gearbox?
      08-11-2016, 07:55 PM   #7
Bucketsbentley
18
Drives: BMW M4
No idea. Best ask a BMW engineer
      08-14-2016, 05:43 AM   #8
aboulfad
aboulfad's Avatar
1593
2015 BMW M4  [10.00]
Are you basing this statement purely on part number change? Sometimes parts numbers change without change in the part itself and vice versa.
http://www.realoem.com/bmw/enUS/show...diagId=28_0018
      08-14-2016, 02:04 PM   #9
Bucketsbentley
18
Drives: BMW M4
Yep part number change. As I said, best talk to a BMW engineer. Not clear what has been updated. BMW don't usually change p/n unless there's been an update of some kind
      08-14-2016, 05:47 PM   #10
CaryTheLabelGuy
CaryTheLabelGuy's Avatar
2634
Drives: 2016 M4 ZCP
Part numbers can also change if there is a new supplier.
CanAutM321115.00
      08-14-2016, 05:54 PM   #11
Bucketsbentley
18
Drives: BMW M4
True but how many different suppliers are able to produce the DCT box to BMW standards. It's complex. Springs I can understand. I for one would be happy if there were no design changes but...
      08-14-2016, 05:58 PM   #12
CaryTheLabelGuy
2634
Drives: 2016 M4 ZCP
We aren't talking about a whole DCT transmission. We are talking about a few parts inside the DCT. Individual parts are often sourced from different suppliers.
The DCT used in the M2/3/4/5/6 is made by Getrag, BTW.
      08-15-2016, 05:44 AM   #13
aboulfad
aboulfad's Avatar
1593
2015 BMW M4  [10.00]
ok I dug a bit about these updated p/n, here's what I found:
- the DCT top level p/n are subject to TeileClearing, "TC":
The affected part is subject to TeileClearing in certain countries. Before the respective part is exchanged, a PuMA case must be generated and a TeileClearing release must be obtained. Detailed information is available in PuMA/DCS Net.
Here's the information from ETK on all the new p/n (AA0, AA9, AC1), so it seems that in order to replace the DCT under warranty after a PUMA requires a TC release for the following countries: CN, DE and ZA.
Its unclear why for these countries only, and under what conditions, issues, seeing as oilpan and hydraulic cover was changed, maybe because of oil leaks ? The PUMA case would detail more info.
      08-15-2016, 05:59 AM   #14
CanAutM3
General
CanAutM3's Avatar
21115
Drives: 2021 911 turbo
You forgot a digit
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black
      08-15-2016, 07:38 AM   #15
CaryTheLabelGuy
2634
Drives: 2016 M4 ZCP
Originally Posted by CanAutM3 View Post
You forgot a digit
That pesky little M2.
Fixed it!
      08-15-2016, 07:03 PM   #16
aboulfad
aboulfad's Avatar
1593
2015 BMW M4  [10.00]
Ok was at a BMW dealer and asked them about the DCT minor revisions, as far as they know, it's only the casing and only for those countries above. I am going to another dealer tomorrow, I'll ask them too! (Obviously not for that reason)
f80post
