07-19-2016, 10:50 AM | #1 |
412
Rep 1,157
Rear Facing Dash Cam Attachment
Does anyone have any advice for the best way to attach a rear facing dash cam in a touring?
At the moment, the one I have is attached using a double sided sticky pad which has to attach to the headliner. It was originally stuck to the glass but I opened the top part of the boot and the short wire didn't have enough slack. Although the sticky pad holds it for a while, it's not long before there's a dangling dash cam. I've toyed with the idea of making a mount but I'm not sure I'd have the skill or materials to make a suitable job of it.
Current: recovering slowly
Previous: F31 340i Ruby Red IIM5 Singapore Grey, F30 335d Moonstone, F30 320d Tanzanite Blue |
07-19-2016, 12:37 PM | #2 |
6419
Rep 8,500
I used a 38mm mild steel right angled bracket and bent it into shape (folded it so that it was almost 180 degrees rather than 90), cut one of the metal sides to reduce its length, slid the bracket so that the headlining fits in the resulting gap, then used strong gel tape to stick the upper side of the bracket (the longer one) to the underside of the roof. Then stuck the camera mounting plate to the exposed part of the bracket.
It works really well, and the camera is rock solid. Photo of the finished job are attached.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
07-19-2016, 01:01 PM | #3 | |
412
Rep 1,157
07-19-2016, 02:18 PM | #4 | |
40
Rep 99
If you can hang on until the weekend I can send you a photo and description of mine. Sorted by the installer. Really good bloke, (but based in Salisbury so a bit far to S Wales! Mines a Mi-Witness system Graham |
07-19-2016, 02:20 PM | #5 |
40
Rep 99
RJ.
If you can hang on until the weekend I can send you a photo and description of mine. Sorted by the installer. Really good bloke, (but based in Salisbury so a bit far to S Wales!) Mines a Mi-Witness system Graham |
07-19-2016, 02:47 PM | #6 | |
412
Rep 1,157
That would be great thanks! It would be the weekend before I'd have a chance to do anything anyway so it's ideal timing.
07-19-2016, 03:00 PM | #7 |
General
17488
Rep 25,115
Do you mean to face back out of the rear window....rather than face back from the Dash showing everyone inside the car?
My car made front page of Bimmerpost
07-19-2016, 03:31 PM | #8 | |
412
Rep 1,157
07-19-2016, 04:15 PM | #9 |
951
Rep 1,643
Take a look at this thread: http://f30.bimmerpost.com/forums/sho...php?p=20198430
07-19-2016, 04:18 PM | #10 |
6419
Rep 8,500
Trying the photos again.
Edit - photo upload from App clearly not working.
07-19-2016, 04:25 PM | #11 |
6419
Rep 8,500
From desktop this time.
