2Addicts
2Addicts
2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Help! Dash cluster flashing?
      07-16-2016, 02:04 AM   #1
koston
koston's Avatar
Australia
37
Drives: M235i
Okay, so I've been driving fairly conservatively during break in. The car is about three weeks old and almost at 1200miles/2000kms. I've hit 4.5k RPM two/three times and have kept speed under 100MPH/160KPH.
Recently, I was driving on the highway and the dash started playing up after I overtook someone (100-115KPH at low RPMs). For reference, the oil temp was at 230F/110C and there was very light rain. I also have an ELM327 on the OBD port and a dashcam connected to the 12V plug.
The dash started flashing every few seconds and is similar to the video above except every light on the dash went out.
I pulled off at the next exit and stopped at the side of the road. Dash continued to flash, so I turned off the car and waited a few minutes.
Restarted the car and it seemed fine. After this, I drove for another two hours without issue.
Has anyone encountered this issue before and, if so, is it a simple fix?
      07-16-2016, 02:41 AM   #2
Moel
17
Drives: M235i
This is just a finger in the air guess, but I know on my old Alfa 159, the odometer would flash in the event of a canbus failure...maybe this is a similar thing?
(A canbus failure in itself is not a bad thing, it just means a component it was expecting to be on the canbus network isn't there)
Alternatively, the clocks are dying as the YouTube video suggests.
      07-19-2016, 07:49 AM   #3
koston
koston's Avatar
Australia
37
Drives: M235i
Thanks, it seems to have fixed itself and the OBD reader isn't showing any codes, so I'm hoping it was just a random glitch.
      07-19-2016, 08:33 AM   #4
ThreeToTwo
England
27
Drives: 2016 6MT M235i
If it's any consolation, my previous E90 had a similar 'event'. I was pulling away from traffic lights at quite low rpm when I noticed the ABS warning light was on. "No brakes!", I thought as I looked again and saw more warning lights, then realised that every warning light was illuminated. My lights were steady, not flashing.
The brakes worked as I reached the end of the traffic stream in front (more traffic lights). I couldn't believe that so many systems had failed so...I turned the car off and then on again after 5-10 seconds. No warning lights and everything seemed to be working.
I had that car for 5 years and it never happened again. I assume a computer somewhere under the bonnet had a once-in-a-lifetime set of events and crashed, a reboot cleared the problem.
      07-19-2016, 03:51 PM   #5
MikeyJ
Drives: ED 4/27/15 - M235i 6MT
Maybe your car just doesn't like Frankie Valli and the Four Seasons?
2addicts
