Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Spacer recommendations for my setup?
      07-11-2016, 07:08 PM   #1
AtlasM
AtlasM's Avatar
285
Drives: '11 E92 335xi 6MT
I have an LCI E92 335xi. It's lowered on B&G springs and Koni FSD shocks. I had an alignment done today with my Ground Control camber plates and set the front camber to -2.5°. There's now a ton of space between the top of the tire and the front fenders. I have 19x8.5" +32 wheels with 235/35-19 tires. I did a quick measurement and it looks like a 15 mm spacer should get me closer to flush but not be too close to the fender. I definitely want to have clearance since you can't roll the plastic E92 front fenders. Does the 15 mm spacer with my setup sound like too much spacer to anyone?
      07-12-2016, 10:38 AM   #2
b-man
b-man's Avatar
604
Drives: 328xi
I ran 19x8.5 +29 with 10mm spacer with 235/35/19. But I had my fenders rolled. I was lowered on kw v1. Stock camber. I rubbed with 15mm spacer though...
You should be fine with 15mm since you have -2.5 camber, but go with 10mm if you want to be safe. I don't think 5mm will make a big difference on how it looks, so I'd go with 10mm
      07-21-2016, 06:33 PM   #3
AtlasM
AtlasM's Avatar
285
I ended up buying a cheap carpenter's square at Harbor Freight to get a more accurate measurement. There was just about an inch from the tire to the inner fender lip. I went with 12mm BMS spacers. Pretty happy with the results. I didn't want to be super flush, just get rid of the excess clearance.
