Angel Eyes Losing Power
07-09-2016, 01:55 PM | #1 |
21
Rep 117
Hi,
I've started a similar thread in the lighting section as I initially thought it may be wiring issue or something non code related but now it's looking like it might be a coding issue. Basically I've retrofitted hid projectors and they are operating correctly after adding the option $522 to the VO etc. but my angel eyes which are tapped into the parking lights only stay on for a very short period (under 30 seconds) before shutting off, this happens with the key out, key in, ignition on, and engine running. And once they shut off the only way to get them back on is turn off and on the ignition which seems to reset the feature which is cutting power. I've checked the voltage with a multimeter and with a parking light bulb in the voltage reads just under 12V indefintely and with an angel eye bulb in when they are lighting it reads just under 12V then suddenly jumps to 0V and they shut off. I've attached my current fsw psw file for the FRM module as it currently stands, any help would be appreciated. My car is a 2006 335D with and FRM1 module. Brian. |
08-24-2017, 04:05 PM | #2 |
Rep 2
You ever figure out your problem? I'm very interested in this build and if possible i would like to pick your brain about it. Appreciate it and thanks in advance.
09-10-2017, 07:48 AM | #4 | ||
36
Rep 216
I was under the impression this was plug and play with coding. Is that not the case? Do you know what pins I'd have to swap? Thanks! |
