07-03-2016, 02:27 PM | #1 |
60
Rep 109
340i mpg and temperature
went to Yorkshire region Porsche day today at Lotherton Hall near Leeds. Not a bad day out and kind of made me miss the club days.
It's about a 90 mile each way journey for me and as I'm still running it in thought I'd try Eco plus mode. Cruise control set around 78 mph and returned 42 mpg each way. Very pleased with that!! Noticed the temperature gauge consistently ran below the 120 mark. I'm so used to seeing a temp needle point straight up that it looked a little odd for it to be left of centre. Do other 340i drivers noticed the same? On a plus side I'm about half way through the running in period!!: |
07-03-2016, 02:50 PM | #2 |
1084
Rep 2,376
re : temperature - yes. re : mpg - the 40i is fantastically economical at constant speed.
Current - X3m Comp
Gone but not forgotten - F80 m3 Comp, F30 340i, F30 - 320i |
07-03-2016, 03:15 PM | #3 | |
211
Rep 389
X5 40d M F15 - July 2018 - Space Grey
Mini JCW F56 - June 2018 - Rebel Green Previous: 340i M F31 2016-18, 2015-16 435i M F32, 2013-15 330d M F30, 2011-13 Mercedes C250, 2008-11 320i E92 |
07-03-2016, 03:27 PM | #4 | |
6659
Rep 15,858
07-03-2016, 03:44 PM | #5 |
687
Rep 589
Temperature - left of center which really messes with my head.
MPG - not run in yet 800 miles only. Went from home to Cornwall last Friday. 250m fully loaded, Motorway and A roads, no faster than 78, 40.1 mpg. Happy with that but not a major issue for me, I had the car for the performance, smoothness and sound. Every journey is an event in this car. Every journey makes me smile, every press of the starter button shouts engineering quality and power. I've called mine 'Hector' it is a hero with the beating heart of a warrior |
07-03-2016, 04:03 PM | #6 |
2281
Rep 4,933
Yep temp is always less than half of centre. I have given up looking at mpg and at 3k miles in all I know is I am going to the garage to fill up slightly less than I was. I could easily go even less but it's so addictive having the rev counter go all the way to 7k odd revs I can't help it.
I normally am in 3rd going round abouts and then pressing on as it's sufficient to make fast progress and so sometimes forget how savage the 340 is when being floored in 1st and 2nd. The 4.7sec to 60 via mlaptimer confirms it (not sure quite how accurate it is mind) which for a rwd estate is non too shabby. Still a very happy camper! |
07-03-2016, 04:41 PM | #7 | |
1084
Rep 2,376
Current - X3m Comp
07-03-2016, 05:00 PM | #8 |
60
Rep 109
Engine starting to loosen up a little and definitely sounding better with each trip!
There is however an annoying squeak from the rear that I've been unable to track down, and it's not my son!! |
07-04-2016, 01:00 AM | #9 |
2647
Rep 3,664
Temp gauge the same on mine. I was curious as I expected it to be straight up.
MPG hovering around 30 but I've only been poor long round town and it's only got 130 miles on it yet
Current: M4 G82
Past: C43, X4 M40i, TTS, M4 CP, 440i, 435d, M235i, 220d, F30, E90, E87 |
07-04-2016, 01:43 AM | #10 |
2812
Rep 4,935
Drives: 340i MPPSK
Same here re: temp.
7,500 miles in and my overall average is 34.0mpg, best for a tankful being 37.5 and worst was 30.76 according to Fuelly.
Life is a state of mind |
07-04-2016, 03:02 AM | #11 |
General
17488
Rep 25,115
340i can't be much fun to drive....all I see are mpg threads...?
MPG really is getting very very good on BMW 3L petrols though. I was pleasantly surprised on the M4 even. Just do a Porsche though and give us the option to put a bigger tank on the car!
My car made front page of Bimmerpost
07-04-2016, 06:25 AM | #12 |
3531
Rep 11,292
I noticed the temp gauge being around the same as described on my M3 and flagged up the same on the F80post forum.
Seems its normal and different to a diesel.
Current: Golf R Mk8Previous: Golf R Mk7.5 Mercedes AMG C63 S Coupe F80 M3 Competition Pack |
07-04-2016, 06:54 AM | #13 | |
6659
Rep 15,858
Petrol engines are running different ECT, according to load. Economy (light loads) runs a higher coolant temperature, reduced as higher engine loads are used. This also has a bigger influence on the oil temperature range, hence running oil up to 150C (although appearing high) is still in the normal working range. In the UK, with our ambient temperatures and typical road driving conditions, there is plenty of oil cooling capacity. We don't normally see oil temperatures reaching the mid (120C) mark. We appear to be at the lower end of oil temperature most of the time, running not much more than the ECT, if at all. In hot climates many of the petrol models have added oil cooling capacity, to keep the oil temperature down in the normal range. |
07-04-2016, 07:52 AM | #14 | |
2021
Rep 1,926
Would it therefore be safe to assume that, in order to burn off all those nasty combustion by-products, a good sound thrashing to increase oil temp could be considered preventative maintenance? |
07-04-2016, 09:13 AM | #15 | |
6659
Rep 15,858
I recall the content of the User Manual my father had with his first BMW, a New Class 2000 Sedan. There was a section on 'driving notes' which included a description of how to "stretch your engine", by using lower gears and extending the rpm. |
07-04-2016, 09:18 AM | #16 | ||
60
Rep 109
07-04-2016, 09:29 AM | #17 |
6659
Rep 15,858
07-04-2016, 09:53 AM | #18 | |
60
Rep 109
Always wanted the 3000 but never got there. |
07-04-2016, 01:48 PM | #19 |
82
Rep 224
07-04-2016, 03:56 PM | #20 |
General
17488
Rep 25,115
That's the spirit, I salute you sir.
