06-29-2016, 07:21 PM | #1 |
Boost Addict
344
Rep 349
Upgrading Pads & Bushings?
Hi guys,
Wondering if there are upgraded bushings available for our cars yet? I only found BimmerWorld's delrin rear sub bushings. I want to tighten up the car, as the car is super loose, with delayed response when turning at high speeds. Its getting annoying Also pads, I want EBC Reds or similar, like Hawk HPS-5.0 but can only find OE style or CoolCarbons for 335i brakes (nonMsport), anyone know of any good cold bite, low dusting pad? Thanks, -San |
07-01-2016, 11:28 AM | #2 |
481
Rep 1,572
According to Hawk's website, they now carry the ceramics for the 335i (this is the 2013 search). I put these in my 2009 335i in 2011 and was very pleased with their performance, low dust and quietness.
Performance Ceramic - Luxury & Touring Compound Rear Brake Pad Pad Description: - Extremely quiet–engineered to reduce brake NVH (Noise, Vibration and Harshness) - Increased stopping power - Increased rotor life - Extended pad life - Ultra-low dust - Stable friction output - Ideal for import and domestic sports cars and luxury cars, sport trucks, vans and SUVs with light towing and hauling duty Part#: HB624Z.642 $111.28 More details Performance Ceramic - Luxury & Touring Compound Front Brake Pad Pad Description: - Extremely quiet–engineered to reduce brake NVH (Noise, Vibration and Harshness) - Increased stopping power - Increased rotor life - Extended pad life - Ultra-low dust - Stable friction output - Ideal for import and domestic sports cars and luxury cars, sport trucks, vans and SUVs with light towing and hauling duty Part#: HB551Z.748 $144.21 |
07-01-2016, 12:08 PM | #3 | |
284
Rep 703
07-01-2016, 01:14 PM | #5 | |
284
Rep 703
2018 M3 ZCP "Edition Velocity"
2018 X3 30i (wife’s) 2017 340i w/ MPPSK & Many M Performance Parts (sold) 2016 328i (sold) |
07-01-2016, 05:44 PM | #6 |
83
Rep 253
EBC and Hawk are meh.
StopTech Sport (not street) works on the street, work on the track x4 20 minute session with repeated aggressive stop from 140+ (auto club speedway) no fade, pedal stayed the same (rbf600). At the end of the day it was my P Zero (rear chunked) that gave up not the brakes. (running brembo with dimple slotted rotors) at a 100+ degree track temp. I brake 50 feet later then CCB M's. And they cost $120 couldn't ask for more really. Only downside is I decided my wheels were going to be black, due to high dust. If you actually follow the bedding procedure (nail them hard 10-20 times from 60+ to 5mph but don't stop after install) prepare to have ur face pull off. |
07-01-2016, 11:34 PM | #7 |
2895
Rep 3,473
07-02-2016, 10:56 AM | #8 |
Boost Addict
344
Rep 349
I use to run EBC Yellow and HP+ for street pads, Im too familiar with wheel cleaning
Was hoping to move towards a more street friendly pad on the F30, without compromising the cold bite. Not worried about fading on the street. If I track, I'll toss in track pads. Thanks for the suggestions guys. |
07-02-2016, 03:25 PM | #9 | |
83
Rep 253
07-11-2016, 07:24 PM | #10 | |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
Otherwise, there's not much out there yet for bushing upgrades. I swapped out front lower control arms (or "wishbones" in BMW speak) to the F8x parts, which have a bearing instead of soft rubber bushing... not to mention they provide additional negative camber ... info here And then there's the Dinan monoball kit to retrofit into the thrust arms. I haven't pulled the trigger on these yet, but intend to shortly, as the stock rubber Tension Strut bushings appear to be a huge source of compliance - particularly under heavy braking. This kit is pricey, but it looks to be a very well-designed and machined system, so you get what you pay for.
Ahead of the curve for specF30
Underated4.00 |
