06-29-2016, 03:29 PM | #1 |
2301
Rep 12,654
KW Variant 3 Suspension Now Available for F87 BMW M2!
[/URL] AutoTalent | KW Suspension | BMW F87 M2| Applications: V3 Please PM or email: Golan@AutoTalent.com with any questions! We are the oldest KW Suspension dealer! KW V3: Adjustable Rebound & Compression Damping Part # 352200BH Want full control? The KW V3 gives you multiple settings for both rebound and compression. You have full access over ride comfort and handling to dial in that perfect setup. Race teams rely on adjustments to get that perfect lap time and having shock controls at your fingertips is key. KW V3 features - Separate adjustments for compression (14 positions) and rebound (infinite settings), Stiffer springs over stock for less bodyroll than the standard suspension, Stainless steel strut/shock bodies and composite spring perches for superior corrossion resistance, Individually height-adjustable: TUV approved lowering range and operation, Expert engineering and design for ease-of-use and long durability, Whether you track the car often or only use it for backroad carving the V3 will give you the tools to set up an ideal handling condition. You can crank it up for smooth and fast surfaces or soften it for city or rough roads. Since each shock is 2-way adjustable you can alter the front-rear balance to account for brake dive or squat during power application coming out of the corner. You are in total control! Coil over suspensions are better engineered suspension options compared to a standard shock + spring package. Since the springs and shocks in a coil over are designed by a team of engineers to work together, there is much better suspension travel and more precisely tuned specifications for spring and shock rates. Using separate shock and spring specs may result in premature coil bind or shock bottoming. And most coil over kits offer more features than the traditional packages. Coil overs are also more useful when larger wheels/tires are used because you can precisely set the ride heights to clear the new tires. Last edited by AutoTalent; 10-02-2017 at 05:08 PM.. |
08-01-2016, 11:03 PM | #7 |
207
Rep 343
08-04-2016, 01:26 AM | #8 |
103
Rep 85
Pm price shipped to Massachusetts thanks
2016 F87 M2 (current)
2019 Gt2 RS(current pipedream) 2016 Cayman Gt4(sold) 2010 E93 M3 (sold) 2012 Wrx Sti (sold) |
08-24-2016, 12:35 AM | #13 |
452
Rep 2,148
Drives: F87 M2 BSM MT
Price shipped to FL?
08-24-2016, 06:48 PM | #14 |
2301
Rep 12,654
10-24-2016, 12:54 PM | #21 |
2301
Rep 12,654
