Advice: Hit & Run, Minor Cosmetic Damage
06-29-2016, 01:14 PM | #1 |
Rep 7
Hello All,
So I found my car after work yesterday with the marks of a bad driver all over the front.... A car somehow hit the front of my car leaving white paint transfer and a number of scratches of varying severity. Here it is as I found it; I was able to get most of the worst parts off with some soap & water and Maguires ScratchX but there is still a fair amount. Overall an improvement...but could be much better. I know it will probably never look the same. Now what remains is some scratches and stubborn spots of paint transfer. I did a little searching and found a couple methods and would like opinions if anyone has tried any; -WD-40 on the paint transfer then gently rub off with a Mr. Clean Magic Eraser? (skeptical, damage clear coat if it still is under there?) -Clay Bar? -Rubbing compounds or any other product recommendations? Waxing after for all methods goes without saying. I don't have much experience in this so any advice is appreciated. Thanks, -T Edit: Close Ups Last edited by BahnBurner; 06-29-2016 at 05:26 PM.. Reason: Added Images |
06-29-2016, 03:39 PM | #2 |
602
Rep 2,703
Drives: 2009 335i - Sport PKG
Zach can help you here http://www.e90post.com/forums/showthread.php?t=1196641
take some close shots |
06-29-2016, 08:57 PM | #3 |
602
Rep 2,703
looks like you will get it repainted
06-30-2016, 02:52 PM | #6 |
360
Rep 5,052
Here's how it works....
If the damage is through the paint, exposing the base coat, primer, or substrate, then the only way to repair it is to repaint. You could also just use touch up if the damage is small enough. If the damage has not penetrated the clear coat, then it is repairable without repainting. The majority of the white marks are probably paint transfer and will be relatively easy to repair. It is common to use a solvent to remove the transfer, but you can also use a cutting compound and dual action polisher. I would use some mineral spirits on a microfiber towel and rub a small area to see if the white paint comes off (test in an inconspicuous area to be safe). Otherwise, a 3" pad and some compound will do the trick... here is some paint transfer from someone hitting the side of their garage. A few passes with M105 on an orange light cutting pad and the white paint transfer was removed. Hope that helps. Let me know if you've got any questions. -Zach |
06-30-2016, 03:45 PM | #7 |
Rep 7
Thank you for the reply. This helps a lot. I think I'm going to go with the M105 and pad approach. It seems pretty straight forward and then I'll just get some touch up paint.
Thanks |
07-05-2016, 08:48 AM | #9 |
602
Rep 2,703
looking good, how did you fix it?
07-05-2016, 09:08 AM | #10 |
Rep 7
Tags |
bumper, cosmetic, hit&run, paint, scratch |
