F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > limits of 340i paired transmission
ARMA SPEED
      06-22-2016, 08:22 AM   #1
insanecoder
1412
Drives: 340isDrive
Anyone know if the 340i is being paired with ZF 8HP45 or ZF 8HP50 ?
I am getting conflicting info..
It seems to me the cheaper transmission is one of the governors on how much you can push this engine in the 340.
ZF 8HP50 is rated at 500NM which is about where MPPK would take it (circa 355hp).. it seems the engineers would not want to exceed the rating of the auto trans.
If indeed its the 8HP45 then at 320 hp its already atop its rating at 450NM..
      06-22-2016, 10:11 AM   #2
Daftasabrush
Fool
Daftasabrush's Avatar
England
1857
Drives: F31 340i
8HP50
It's probably already pushing the 'box on paper in standard form let alone with the MPPSK.
There's likely to be some tolerance in the limits on the 'box as it would have been designed in conjunction with BMW so I doubt they would have put an underspecced 'box in the car. There's almost certainly very little room for tuning beyond the MPPSK though.
http://www.etk.cc/bmw/EN/search/sele...CE/24/24_1504/
      06-22-2016, 08:52 PM   #3
F32Fleet
F32Fleet's Avatar
3572
Drives: 2015 435i
have you searched your VIN under realoem?
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      06-22-2016, 09:33 PM   #4
HitmanHearns
97
Drives: 14' Infiniti Q50 / 16' Audi A4
Can someone please explain this thread to me like I'm five?
Appreciate 3
      06-23-2016, 12:31 PM   #5
Paul_M3
Paul_M3's Avatar
56
Drives: 2018 Imola Red M3
each transmission has power limits, ones less and ones more. He wants to know which one the 340 has so he knows the limits
2018 BMW M3 ZCP- Imola Red
Follow me on Instagram: @hsdvisuals
      06-23-2016, 03:44 PM   #6
//M
243
Drives: M2 Comp
Originally Posted by Daftasabrush View Post
8HP50
Based on previous ZF gearbox's they can hold way more then rated torque. The ZF 6hp21 in the N54 335 is considered solid to 550wtq with proper fluid changes. A cooler will help a lot as well, its linked to engine coolant so it heats up quickly but then gets hotter then optimal for high power application.
This trans is likely solid to 450wtq no problem.
      06-24-2016, 09:13 PM   #7
zinner
zinner's Avatar
559
Drives: `17 X5 35d/`15 335i/`18 M550IX
The limit is exactly the amount of Tq they provide from the factory MPPK tune. Gonna have the find out the real one on your own.
      07-12-2016, 08:21 PM   #8
insanecoder
1412
Drives: 340isDrive
The mppk tune is 500Nm which pushes right up against the rated 8HP50 @ 355 hp.
So the guys running JB4 are on paper stressing the tranny out.. an 8HP70 would have been great but its too big.
I'm sure the tranny has built-in tolerance but what is it?
f30post
