INPA - identify AGM or lead-acid battery?
06-19-2016, 12:29 PM | #1 |
Rep 17
Hi,
From many posts I can see how to read the AH for my battery. It is 90ah. But I can't tell if it is AGM. I see some posts where people are debating about their batteries - if it's white or black, something about wells, etc... But nothing definitive. Is there a way to identify AGM through INPA? I would like to replace my battery without having to recode - so I need to buy the correct one. Thanks, Nachum 2011 (March) 335d Here's my PM Field 2: Battery is white made by Exide S: 6 21 7 604 821 AW: 61 21 7 604 819 525679 - 10 IT 12V 90 Ah 720 A (EN) 160 RC 720 CCA (SAE) Last edited by nachumk; 06-19-2016 at 12:41 PM.. |
06-19-2016, 01:03 PM | #2 |
529
Rep 2,503
Not sure about INPA but use NCS Expert, run a basic job and have a look at your VO text file in the WORK folder.
You'll see an option similar to one below: B046 BATT_46AH //46 Ah-Batterie B055 BATT_55AH //55 Ah-Batterie B070 BATT_70AH //70 Ah-Batterie B080 BATT_80AH //80 Ah-Batterie B090 BATT_90AH //90 Ah-Batterie A070 BATT_AGM_70AH //70 Ah-AGM Batterie A080 BATT_AGM_80AH //80 Ah-AGM Batterie A090 BATT_AGM_90AH //90 Ah-AGM Batterie If it starts with a B the CAS is programmed for a standard battery. If it's got an A it's programmes for an AGM. |
06-19-2016, 01:37 PM | #4 |
Rep 17
I see in a file called FSW_PSW.TRC with these lines:
GETRIEBE_GAENGE 6_gaenge KLASSE_BATTERIE 90ah STROM_RUHE wert_01 Looks like non-agm battery. To get this, I chose F1 (VIN/ZCS/FA), then F3 (ZCS/FA f .ECU). Selected E89. It then seemed to read the VIN and some information from the car. Does this sound right? Also, I tried to figure out how to run a basic job to get a VO output. Is this file the VO output? I was somewhat confused by that. Looks like I'll be buying a 90AH non-agm battery. Thanks again, Nachum |
06-19-2016, 01:52 PM | #5 |
456
Rep 2,749
if your battery have white or grey plastic casing and optical status indicator - it's lead acid
if you battery have black plastic casing and there is no status indicator - it's agm
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
06-19-2016, 01:57 PM | #6 | |
529
Rep 2,503
This is your vehicle order (VO). Worth checking what your car is codes for and if battery matches up. |
06-19-2016, 02:15 PM | #7 |
Rep 17
I see B090 at the end of fa.trc, so it is standard 90AH. I can't find a battery with 720 CCA and 90AH for my car online. The recommended one at a battery dealer nearby is:
https://www.batteriesplus.com/batter...ional/sli49h8m 1. Can I use 100AH? The list includes 90 and 110, not 100. 2. Is it OK if I try and reprogram my car now for 100AH (if possible), and if I succeed go and buy the battery? I would like to learn how to do this, but if I can't, I'm just gonna pay them to install it. After I buy the battery and install it, I would perform the "register a new battery" process. Thanks, Nachum |
06-19-2016, 04:38 PM | #8 |
Rep 40
Flame off folks. An AGM is a type of lead acid battery. The difference is that one type of battery is a "flooded cell" , meaning the zinc and lead plates swim around in cells full of liquid acid. This type is what all the posts refer to as a "lead acid" battery. In the other the acid is absorbed on glass mats (AGM). End. Flame back on.
06-19-2016, 10:15 PM | #9 |
Rep 17
After trying to find a 90ah standard battery and failing, I ended up buying an 80ah agm battery from a local store. I have tried to program the car to use the new battery and it doesn't seem to work.
I followed the ncsexpert directions from a PDF off 1addicts.com of modifying FSW_PSW.MAN and modifying the klasse_batterie to 80ah_agm, then doing coapireadsggetfswpsw and i get 'basic function perfect ended'. I then switched to sg_codieren and I execute the job. the system restarts. But when I reread using read ecu, it is still 90ah. I have even run the register new battery steps as well. Nothing changed. I then tried this sequence (using FA_Write): http://www.e90post.com/forums/showthread.php?t=775420 And I got this error: Please help! Thanks, Nachum |
06-19-2016, 10:45 PM | #10 | |
28
Rep 62
06-19-2016, 10:49 PM | #11 |
¯\_(ツ)_/¯
170
Rep 425
then sg_codieren and read again to confirm it's been changed. not basic functions getfswpsw, see? then you can use tool32 to "reset" the learning
30FF
06-19-2016, 11:27 PM | #13 |
Rep 17
One last thing. I just finished coding the battery type and registering the new battery. I then cleared codes in INPA. But this code still comes up:
5DF4 - Power supply too low Is it possible I broke a sensor cable during installation of the battery? Should I wait a few days and clear / check again? Thanks, Nachum |
Tags |
335d, battery, inpa |
