BT coding with 2URAD and MULF2, PLEASE HELP!
06-18-2016, 12:09 PM | #1 |
Rep 167
Hey ALL,
I finally got everything connected for my retrofit, and coded, but cant get it to work. I have an 07 e92, no idrive, with BWW professional radio. There was no TCU or ULF in the truck, so I opted to put in a MULF2 High basis SVS. My car came with $640 already done, so I added my Antenna, MULF2 and microphone. I coded $644 and $6FL to my VO, and update the ULF_EXE to active and bluetooth to active on the 2URAD. I now have phone on my radio, but it shows 2 dashes ( --), and I cant access it. I have reset the radio, and nothing. I have tried resetting the mulf2 via NCSexpert and it doesnt find it. I tried resetting it via tool32, and it doesnt find it. I did a full module identification in INPA, and I dont see anything labeled MULF2 (or 2MULF like ncsexpert). Am I missing something? I checked fuses, as well. Any ideas?
The Old: DG G35 6mt coupe The New: AW 6mt E92 335i |
06-18-2016, 02:43 PM | #2 |
456
Rep 2,749
you need add MULF2 MOST circuit to the MOST loop via switching it's ends to another part of the MOST concentrator under rear left seat trim, near door
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
06-18-2016, 03:35 PM | #3 |
Rep 167
You're right! I did that and now I can communicate with the MULF2, but still shows me Phone -- on my radio I was able to SG_RESET the unit, but nothing still. I tried pulling the $644 and $6FL from VO and adding it back, and the same with changing ULF_ECE and BLUETOOTH_RAD2 back to nicht_aktiv and then back to aktiv.
06-18-2016, 05:33 PM | #4 |
Rep 167
Partial Success!!! SO I ended up performing a SG_RESET on all modules and that seemed to do the trick! My phone now connects and makes calls, but the mic isnt working lol
06-18-2016, 11:46 PM | #5 |
BimECU
193
Rep 759
did u do default coding?
06-19-2016, 09:39 AM | #6 |
263
Rep 749
06-19-2016, 10:03 AM | #7 |
456
Rep 2,749
you do not need icom to code MULF on e90, this is requirement for old e60
06-21-2016, 07:48 PM | #9 |
Rep 167
Yeah, and that seemed to do the trick
Yeah. There were a few mic wires in the glove box that needed to be moved around. I finally got it all connects and working
06-30-2022, 07:59 PM | #10 | |
15
Rep 93
